1- port channelized OC-3/STM-1 benifites
I need to know the difference between connecting a STM-1 fiber cable from ISP to the module"1- port channelized OC-3/STM-1" and connecting to giga interface of supervisor engine of Router c 7606
Hall of Fame Super Gold
Re: 1- port channelized OC-3/STM-1 benifites
Actually, you would use the non-channelized card.
The benefit is that you can monitor the true state of the fiber circuit, and do not have to pay monthly to the ISP for a converting device .
Hall of Fame Super Silver
Hello Yasmena,
connecting a POS fiber based link to a GE fiber based port produces no link at all.
they are both using fibers, lasers and photodiodes but POS is totally different uses SONET/SDH
so unless you want to pay for a service provider device to act as a converter you can use a POS port.
if  you have a flexwan module installed in your C7606 you could consider to use a PA POS
if you have a SIP module (200 or 400) you can look for POS STM-1 SPA submodules
as noted by  Paolo you likely don't need the channelized version (unless you have it already on the system)
Hope to help
Giuseppe
Thanks for your replies , However i need to know if it really a big value to transfer my connection to use that channelized  module or not , are the ISP has to use the same module in front of my connection , the fiber cable is differ  , the module accept the configuration of BW  limitation & tunneling  as GRE tunnel or not .
Hello Yasmena,
May you explain what is your current ISP connection?
Are you evaluating a new ISP proposal?
if they offer you an STM-1 OC3 link they need to use a similar STM-1 ? short answer  yes
a GRE tunnel can  be supported over it, this depends only on the supervisor model on your C7606.
about QoS exact tools that are available depend from the combination linecard / module but the answer should be positive for both combinations (flexwan/PA or SIP/SPA)
Hope to  help
Giuseppe
the ISP connection is a fiber cable through a converter connected to SPF port of supervisor engine .
yes , is it better at all or not  and specially for my setup the as 2 STM1 on different locations connected to each other by a 2 gre tunnel with bw determination based on layer 2 vlan across the provider(pass vlan  tag throug  trunk ).
SPA 400, i don't know about SIP
Kindly i need to know all advantage and knowledge about the 2 solutions .
Thanks alot
As indicated above. It is better to not use converters because you can monitor the true status of the circuits, apply QoS directly and effectlivey, moreover there is one less device that can fail and is charged in the bill.
Silver
Earlier you need a converter box if ISP want to give you GE interface instead of STM. But now Same SDH box  can provide you either STM or GE interface you dont need any converter box if ISP have right kind of box in your facility.
What is the speed are you looking at is STM 1 (155Mb )is enough or you need more. If need more then you can have it on GE interface only thing you have to see the distance whether ISP can provide you GE interface on Copper or fiber  cable for that disatnce. You need to check the feature you are looking is available on GE card or STM card.
843
