1-port OC-3 ATM Enhanced perf Single mode Long NM 3
yzakhem1001
Dear All,
we have a cisco 3745 equipped with "1-port OC-3 ATM Enhanced perf Single mode Long NM 3" Module , do the specification of this midule match the G. 957 Standard ?
second question : is it possible to connect this module to single mode mode fiber of 5 km length maximun coming from Service Provider without using any attenuator ?
Thanks and Regards
Yaacoub
mheusinger
Level 10
Level 10
the best way to go is to request from the SP the information about the dampening of the specific fiber to be used. Usually this is measured during initial installation of the fiber. Once you have the value and also get the info about the other ends transmitter output power you can calculate the power your receiver has to expect. Compare it with the receiver specs and you will know whether an attenuator is needed or not.
Hope this helps! Please rate all posts.
Regards, Martin
