10Gig port-channelling on 7609
Hi Folks, hope I'm posting in the right group.
Has anyone port-channeled two 10G links across separate line cards in a 7609? I want to create a 20G port-channel between two 7609's but each 10G port on a separate line card (6704). Anyone experience any issues port channeling this way? Pro's or Con's?
Both 7609's have Sup-720's 3BXL, but the routers are running at DFC3A because the line cards are DFC3A.
- TM
Re: 10Gig port-channelling on 7609
TM
You can port-channel 2 10G links across seperate modules.
No potential isssues with that deployment.
i have the configurations setup on over 20 7609 routers.
awesome. Thanks man. I figured as much thought I'd throw it out there.
Thanks again,
- TM
143
