Mark
I checked the software download page on the Cisco site and am surprised to find that there is not a 12.4(6) release listed for the 3640. In general what they mean when they say that upgrade to 12.4(6) is required is that upgrade to 12.4(6) or a later release is required. I am pretty confident that if you upgrade to the 12.4(7), 12.4(7a), or 12.4(8) release which are available for the 3640 that your CCM5 should run. If you are concerned about this and want more than my opinion then I suggest that you contact the TAC with this question.
Rick
Rick
