10-01-2005 02:04 AM - edited 03-03-2019 10:38 AM
hi all
i have a 1300 series AP/BR.
part no:AIR-BR1310G-E-K9-R (ETSI)
my external antenna is "AIR-ANT24120" 12dbi.Bcoz of some TRA issues i'm forced to use 5.725-5850.From TRA i got the instruction that, if you put 12 dbi or 13.5 dbi antenna the maximum power is should not exceed " 2W max.mean EIRP".
20 dbm/Mhz max. mean EIRP density.
so in this case how can i proceed with
1300 AP/BR. will this unit support 5.7 band.i need to change this unit? please give your suggestions.
Regds
Binoy.
10-01-2005 08:26 AM
1300s use 2.4.ghz. they dont use the 5.x ghz band.
10-01-2005 08:07 PM
hi shanky thanks for your reply.is there any option in 1400 for 5 Ghz support.
from TRA i got the information that if i use 12 dbi or 13.5 dbi its transmission power exceeds 2 Watt EIRP.They said upto the antenna it's ok.but from the antenna transmission power is high.
how can i convert the 12 dbi and 13.5 dbi into milliwatts.
Regds
Binoy.
