Community Member
1700 ADSL wic card
I want to configure two different adsl lines from two different operators for
Is there any ADSL WIC card with two ADSLoPOTS port or i need to have two different cards for each line.
In both the cases please suggest me the PART no required for cisco 1700
1 ACCEPTED SOLUTION
Re: 1700 ADSL wic card
Hi Sachin
You can make use of Cisco 1841 Series router which comes with 2 WIC slots which you can make use for installing the ADSL cards and 2 ethernet ports for your local lan..
http://www.cisco.com/en/US/products/ps5875/index.html
I feel its the best bet available out there when compared to Cisco 1700 series routers since the later may be phased out by any time..
regds
hi sachin
AFAIK you need to have WIC-1ADSL card installed to support ADSL0oPOTS.
I feel you need to have 2 such WICs to connect to 2 different SP.
http://www.cisco.com/en/US/products/ps5853/products_data_sheet0900aecd8028aa5a.html
Do mention the router model being used over there for this purpose..
regds
Community Member
model not yet decided i want to use some low end router. can you suggest me some models matching my requirements --
--two adsl wan connections
-- one lan connection
-- static routing
I want to use these two adsl wan connections in redundancy or load balancing what configuration is required
Hi Sachin
regds
194
