1701 bridging 2 ip subnets
Can anyone advise please. ISP has assigned a single static ip address of xxx.xxx.xxx.xxx . They have now assigned 6 more static addresses but on another subnet. The router is configured for rfc 1483 bridging with the single static ip assigned to both ATM and FastEthernet. This works fine but how can I add the second subnet of ip's so that traffic is passed from the router to the firewall's public address which is one of the additional 6 static ip's. Your help is much appreciated.
Re: 1701 bridging 2 ip subnets
Can you post the config?
JD
JD
Thanks for replying. Config is below. I have had to change the ip addresses for security reasons. The second subnet given to me by the ISP as we required 2 static addresses is xxx.xxx.xxx.xxx/29. Can I just use 1 of the new addresses for the interfaces or do I need to route to them? I would really like to AVOID using NAT as we will have ipsec VPN terminating on the firewall.
Thanks your help is much appreciated.
version 12.3
no service pad
service timestamps debug datetime
service timestamps log datetime
service password-encryption
hostname visitorXS
boot-start-marker
boot-end-marker
username xxxxxxx privilege 15 password 0 xxxxxx
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
no ip cef
interface ATM0
mac-address 000f.f72d.ae77
ip address 193.77.193.186 255.255.255.255
no ip route-cache
no atm ilmi-keepalive
bundle-enable
dsl operating-mode ansi-dmt
hold-queue 224 in
pvc 8/35
encapsulation aal5snap
interface FastEthernet0
no ip route-cache
speed auto
bridge-group 1
ip classless
no ip http server
control-plane
bridge 1 protocol ieee
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
end
Hall of Fame Super Bronze
interface ATM0
ip address [new ip address block] secondary
no ip route-cache
bundle-enable
hold-queue 224 in
pvc 8/35
no ip route-cache
speed auto
bridge-group 1
You can have multiple IP addresses assigned to an interface? Thats great. I will give it a go. Thanks for the help.
In my opinion, the if an ISP is able to give a different network pool for you then they must have made routing arrengements for you in their setup.Hence, if you give directly the new subnet's ip to your firewall, then it should work without giving secondary IP in your router.
Can you give it a try...try giving that IP in any of your PC, without giving that secondary IP?Make sure that the PC is connected to the same switch to which your router is connected to...
Pls rate helpful posts.
JD
JD,
The router in question is the edge device between the customer and the ISP. How the new IP subnet would be bridged to the customer's DMZ devices ?
JD
Thanks. I shall give that a go first. I was thinking along the same lines but wasnt sure if the router needed to know about the extra subnet as a bridge has to be on the same subnet?
Yes, make sure to use the 'secondary' keyword on the command.
Please rate helpful posts.
115
