1711 etherswitch question
is66rlhntadm
the other day we were setting up a 1711 for a disaster recovery plan and anyway
we needed a 2 port switch temporarily and only really needed 1 of the prots on the etherswitch permanently
so I figured we should be able to put ports 3 & 4 in a seprate Vlan and leave port 1 in vlan 1 so I did the following
vlan database
vlan 2
exit
conf t
int fa 3
sw acc vlan 2
int fa 3
sw acc vlan 2
end
but it didn't work
we came up with a workable solution to be corrected soon
but I still would like to figure out why it didn't work
6 Replies 6
Edison Ortiz
You created the Layer2 Vlan and assigned port membership, but if you needed those workstations to reach devices outside that Vlan, you needed to create a Layer3 interface for Vlan 2.
For instance:
interface vlan 2
ip address x.x.x.x y.y.y.y
and configure the workstations w/ default gateway pointing to Vlan 2
__
Edison.
no I didn't need vlan2 to have a L3 interface
it was a temp fix to not having a cross-over cable
(just making a 2port L2 switch)
the Co-Lo had their stuff configured wrong
at first they had a trunk port going to our rack
in testing the link (after they made their port an access port) we found that we ether nedded a cross-over adapter or a switch inbetween our router and the Co-Lo's cable and having only brought one stand alone switch with us we were trying to come up with a temp fix that would work till we can get an other switch up there or get them to fix the config
In a inter-switch connection, you always need a crossover cable or a switch capable to support auto-mdix.
http://www.cisco.com/en/US/tech/tk389/tk214/technologies_tech_note09186a0080094781.shtml#appc
HTH,
__
Edison.
what we wanted was to connect their cable to our router but that wouldn't work (I think they already made it a crossover cable so we need to uncross it)
so as it was we needed a switch inbetween out router and their cable
at this point its more ceriosity as to why my temp workaround didn't work as my boss is going up their today with a crimping tool and a few ends to change our end of thier cable to the "A" spec
Can you explain in detail "what didn't work" and "what was the workable solution" ?
__
Edison.
quick topo layout
Planed
(Co-Lo)-(1711-ISA-Switch-Servers)
pluging the Co-Lo's ethernet cable into the on-board Fastethernet port didn't work (not even activity leds)
a testing workaround was to plug the Co-Lo's cable into a switch and then a cable from that into the fa0 port
so as we didn't want to use the same switch for the servers as to link to the Co-Lo we tried
(I know a bit crazy)
(Co-Lo)-(vlan2/fa3)
(vlan2/fa4)-fa0
(fa1/vlan1)-(ISA/wan-port)
(ISA/lan-port)-switch
switch-servers
the temp(undesirable) solution that quite soon will be changed is
(Co-Lo)-switch-1711-ISA (with the 2 most important servers pluged into the etherswitch and both ports of ISA also pluged into the etherswitch)
the undesirable solution has worked good enough but obviously is not a very good way to do it (well niether is the vlan2 idea but it should have worked)
