1720 router and wic1-dsu-t1
I'm new here so it may sound stupid but i'll try anyway.
I have a 1720 router with 1 wic1-ds1-T1. Can I connect a MUX directly to the wic and forward it to another router+MUX?
I put a cable between the Mux and wic and the serial interface goes up but the line goes down after a few seconds.
Tks.
1 REPLY
Silver
Re: 1720 router and wic1-dsu-t1
I cant tell exactly what you want to do from the description, but it sounds like you want to create a T1 L2 trunk connection between the 2 MUXes using the routers.
If so, it wont work, you need an NM-CEM-4TE1:
http://www.cisco.com/en/US/products/ps5855/products_data_sheet09186a00802045f5.html
96
