1720 wic-1enet connecting to ADSL ISP
Good afternoon.
I have set up my 1720 router with wic-1enet to connect to my dsl modem..I have gotten the configuration to obtain a dynamic IP through Dialer1. I cannot figure out how to obtain the DNS IP from my ISP. Can someone point me in the right direction? I do not have the running-config right now to show, I am at work and the router is at home. Thanks, Bob T.
Bronze
Re: 1720 wic-1enet connecting to ADSL ISP
A glance at the running-config will really help for providing some comments.
1720 router.
IOS file: c1700-03sy756i-mz.121-5.YB1.bin
Here is the config:
sho run
Building configuration...
Current configuration : 1335 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname 1720
logging rate-limit console 10 except errors
enable secret 5 $1$uT2W$WqtDQzhsD2gJlcoRwVcrv0
memory-size iomem 25
ip subnet-zero
no ip finger
ip audit notify log
ip audit po max-events 100
no ip dhcp-client network-discovery
vpdn enable
no vpdn logging
vpdn-group 1
request-dialin
protocol pppoe
interface Ethernet0
no ip address
no ip mroute-cache
full-duplex
pppoe enable
pppoe-client dial-pool-number 1
interface FastEthernet0
ip address 192.168.0.33 255.255.255.0
ip nat inside
speed auto
full-duplex
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname vze3dhzw
ppp chap password 7 071D34421850150404
ppp pap sent-username vze3dhzw password 7 05191301771542080A
ppp ipcp dns request
ppp ipcp wins request
ip nat inside source list 10 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
access-list 10 permit 192.168.0.0 0.0.0.255
dialer-list 1 protocol ip permit
line con 0
password cisco
login
transport input none
line aux 0
line vty 0 4
password cisco
login
end
I can connect to my ISP and grab an IP address. I assigned 2 DNS server IP addresses to my host computer, and can get to google and some other websites. The issue now is that I cannot connect to all web sites, although I can ping ok and tracert ok. Here is a snapshot of a DEBUG NAT output:
> 1:00:29: NAT*: s=192.168.0.8-&g t;64.222.172.105, d=63.211.66.22 [17767]
> 01:00:29: NAT*: s=63.211.66.22, d=64.222.172.105->192.168.0.8 [23027]
> 01:00:29: NAT*: s=192.168.0.8->64.222.172.105, d=63.211.66.22 [17770]
> 01:00:29: NAT*: s=63.211.66.22, d=64.222.172.105->192.168.0.8 [29612]
> 01:00:29: NAT*: s=192.168.0.8->64.222.172.105, d=63.211.66.22 [17772]
> 01:00:29: NAT*: s=63.211.66.22, d=64.222.172.105->192.168.0.8 [23028]
> 01:00:29: NAT*: s=192.168.0.8->64.222.172.105, d=63.211.66.22 [17774]
> 01:00:29: NAT*: s=63.211.66.22, d=64.222.172.105->192.168.0.8 [29613]
> 01:00:29: NAT*: s=63.211.66.22, d=64.222.172.105->192.168.0.8 [23029]
> 01:00:29: NAT*: s=192.168.0.8->64.222.172.105, d=63.211.66.22 [17777]
> 01:00:29: NAT*: s=192.168.0.8->64.222.172.105, d=63.211.66.22 [17779]
> 01:00:43: NAT: s=66.179.235.37, d=64.222.172.105->192.168.0.8 [4899]
> 01:00:43: NAT*: s=192.168.0.8->64.222.172. 105, d=66.179.235.37 [17847]
> 01:00:54: NAT: expiring 64.222.172.105 (192.168.0.8) tcp 1279 (1279)
> 01:00:54: NAT: expiring 64.222.172.105 (192.168.0.8) tcp 1278 (1278)
> 01:00:54: NAT: expiring 64.222.172.105 (192.168.0.8) tcp 1277 (1277)
> 01:01:27: NAT: expiring 64.222.172.105 (192.168.0.8) tcp 1283 (1283)
> 01:01:27: NAT: expiring 64.222.172.105 (192.168.0.8) udp 1048 (1048)
> 01:01:28: NAT: expiring 64.222.172.105 (192.168.0.8) tcp 1287 (1287)
> 01:01:59: NAT: s=192.168.0.8->64.222.172.105, d=66.179.235.37 [17986]
> 01:01:59: NAT: s=192.168.0.8->64.222.172.105, d=216.239.37.104 [17987]
> 01:01:59: NAT: s=192.168.0.8->64.222.172.105, d=63.211.66.22 [17988]
> 01:01:59: NAT: s=192.168.0.8->64.222.172.105, d=63.211.66.22 [17989]
> 01:01:59: NAT: s=192.168.0.8->64.222.172.105, d=198.133.219.25 [17990]
Where you see the "expiring message is where the web sites are hanging up. I do not know if it is a speed, duplex,timeout, or dns problem. Any help would be appreciated.
137
