1721 Configured for PPPOE...I think?
This thread is based on the configuration shown below. I have a 1721 connected to SBC via PPPOE. I'm using the router as the PPPOE client and have configured FE0 as the gateway and set up DHCP.
When I plug my laptop into FE0 I get an IP address. I can also set up a static address on my laptop and things work fine. However, I have a SCO server that was connected to the internet vi a Linksys router but now can't find the gateway when connected to FE0.
So I'm wondering if my config is missing something or has something wrong. SBC gave me five IP address but I only need one for now and can use the 192 addresses.
How should I set up FE1-FE4 so that I can plug other machines in to those ports and get an IP address and have them connect? I'm thinking I just create a VLAN and assign it to the port, like this:
interface Vlan26
description router interface for LAN segment
ip address 192.168.0.1 255.255.255.0
ip nat inside
interface FastEthernet1
description Connection to Wireless LAN
switchport access vlan 26
no ip address
At any rate, some guidance would be appreciated here. Special thanks go out to thisisshanky and spremkumar for helping me with the initial config.
Thanks!
Jon
Router#show run
Building configuration...
Current configuration : 1470 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1
ip dhcp pool nap_dhcp_pool
network 192.168.0.0 255.255.255.248
default-router 192.168.0.1
dns-server 206.x.x.x.13.31.12
ip cef
vpdn enable
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/35
pppoe-client dial-pool-number 1
interface FastEthernet0
ip address 192.168.0.1 255.255.255.248
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface Vlan1
no ip address
interface Dialer1
mtu 1492
ip address <STATIC IP> 255.255.255.248
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname <USERNAME>
ppp chap password 0 <PASSWD>
ppp pap sent-username <USERNAME> password 0 <PASSWORD>
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 192.168.0.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
end
  • WAN Routing and Switching
Silver
Re: 1721 Configured for PPPOE...I think?
I want to know one information regarding your DHCP server.Is the DHCP server residing in different VLAN from the connecting client's VLAN?.If different, then you may have to go into the VLAN in which the DHCP client resides and in that interface VLAN configuration type "ip helper-address command .This commands forwards DHCP UDP packets.
Nope, same VLAN. In fact, I haven't set up any VLAN yet as it's just plugged into FE0.
I'm working on a config right now that might do the trick though...will update this post when I get it done.
Thanks!
135
