1721 for Voip & Data & MPLS
Can i use 1721 for IP telephone & Data.? If yes than what is IOS Part#. If not then which 1700 model and what IOS support Ip telephony and Data.?
Also which router is compatible for MPLS?
regards
sk
1 REPLY
Re: 1721 for Voip & Data & MPLS
the 1721 offers QoS features and supports VoIP and data in transit. Y
ou will not be able to use it for Call Manager Express and other voice related features are missing as well. So it depends on what you mean with "support".
MPLS routers start with 1800/2800 and 2691, 3640 and 3700 upwards.
Hope this helps! Please rate all posts.
Regards, Martin
115
