Community Member
1721 Router Question
Hi, I'm new to Cisco h/w and have been self training on reconfiguring a 1721 router with a 1DSU T1 WIC. The router was originally for our internet connection. The left slot has the above WIC the right slot is empty. What I want to do is simply use the router to connect to a seperate network within our facility. My question is, do I need to use a different WIC card and if so, what should I use? THanks.
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: 1721 Router Question
Hi, you only need to connect a a switch that does vlans and configure vlan encap on the fastethernet interfface.
Alternatively you need WIC-1E.
Both solution will allow hosts on the two segments to communicate but NOT at wire-speed,
thing for which you should get a L3 switch, the smaller of these is WS3560-8PC.
Then the WIC-1ENET should work just fine! Tn IOS you will see a new ethernet interface which you would need to configure and connect to the other site.
What is the connectivity to the other location? Copper, fiber, T1?
Community Member
Sorry, it is copper. (Cat 5e).
OK, then Paolo's post is right on, either the WIC-1ENET or you could connect two switches together. The two switches option will give you better performance.
Community Member
We don't have a spare L3 switch but do have the router. When you say " Not at wire speed" is that because the WIC card only supports 10mbps?
The switch does not have to be layer 3. You can do layer 2 but you would have to change some routing around which may not be worth it. How much inter-site traffic do you expect?
Community Member
There would be very little traffic through this router.
105
