Webcast-Catalyst9k
1721 to ISa ipsec tunnel
where can i find a template config to configure a 1721 to ISa ipsec tunnel and what ver of IOS is required for the 1721?
Brad
Re: 1721 to ISa ipsec tunnel
Hi Brad
Is it going to be router to router IPSEC Tunnel ? or what kinda device going to be there in the remote end ?
for configuration purpose you can refer the below link ..
http://www.cisco.com/en/US/tech/tk583/tk372/tech_configuration_examples_list.html#anchor18
Also refer Cisco IOS Software Feature Sets under the link to find out the feature set required in your box to have ipsec configured..
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a00800920ec.html
regds
Its going to be a router to ISA connection.
1721 <-> MS ISA server ( needs to create an IPSEC tunnel.
135
