1750 drops connection after hours
All, I have a remote location that uses SWB DSL connection. After hours, the 1750's E0 interface stops responding to ping. I have tried keepalives and have had the same problem. I have called the ISP three times and they can find no problem. Last night, the router was bouncing up and down 10 times. PLease help.
Current configuration : 3853 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname xxxx
no logging on
enable password 7 xxxx
username xxx password 7 xxx
memory-size iomem 20
ip subnet-zero
no ip finger
no ip domain-lookup
ip host test 2005 192.168.18.1
ip dhcp excluded-address 192.168.18.1 192.168.18.20
ip dhcp pool xxxx
import all
network 192.168.18.0 255.255.255.0
default-router 192.168.18.1
domain-name xxx.xxx.com
dns-server 172.17.2.60 xxx
netbios-name-server 172.17.2.60 172.17.2.30
netbios-node-type h-node
lease 30
ip dhcp pool jdirect1
host 192.168.18.20 255.255.255.0
hardware-address 0030.c154.724b
client-name NPI54724b
ip dhcp pool jdirect2
host 192.168.18.19 255.255.255.0
hardware-address 0030.c153.bdbc
client-name NPI53bdbc
chat-script modem ABORT ERROR "" "ATDT\T" TIMEOUT 60 CONNECT \c
crypto isakmp policy 11
xxx
authentication pre-share
crypto isakmp key xxxxxx address xxxxxx
crypto ipsec transform-set sharks esp-des esp-md5-hmac
crypto map nolan 11 ipsec-isakmp
set peer xxxxx
set transform-set sharks
match address 121
interface Ethernet0
ip address xxxxx 255.255.255.248
ip nat outside
no ip route-cache
no ip mroute-cache
half-duplex
crypto map nolan
interface FastEthernet0
ip address 192.168.18.1 255.255.255.0
ip helper-address 172.17.2.30
ip helper-address 172.17.2.255
ip helper-address 172.17.255.255
ip directed-broadcast
ip nat inside
no ip route-cache
no ip mroute-cache
speed auto
interface Async5
ip address 170.1.1.18 255.255.255.0
encapsulation ppp
keepalive 10
dialer in-band
dialer idle-timeout 300
dialer string xxxxx
dialer-group 1
fair-queue
ppp authentication xxxx
interface Dialer1
no ip address
no cdp enable
router eigrp 100
network xxxxx
network 170.1.0.0
network 172.20.0.0
network 172.21.0.0
auto-summary
no eigrp log-neighbor-changes
ip nat inside source route-map nonat interface Ethernet0 overload
ip kerberos source-interface any
ip classless
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
ip forward-protocol udp netbios-ss
ip forward-protocol udp 42508 xxxxxxxxx
ip route 0.0.0.0 0.0.0.0 Async5 200
no ip http server
no logging trap
access-list 110 deny ip 192.168.18.0 0.0.0.255 172.16.0.0 0.0.255.255
access-list 110 deny ip 192.168.18.0 0.0.0.255 172.17.0.0 0.0.255.255
access-list 110 permit ip 192.168.18.0 0.0.0.255 any
access-list 120 permit ip 192.168.18.0 0.0.0.255 any
access-list 121 permit ip 192.168.18.0 0.0.0.255 172.16.0.0 0.0.255.255
access-list 121 permit ip 192.168.18.0 0.0.0.255 172.17.0.0 0.0.255.255
access-list 150 permit esp host xxx host xxx
access-list 150 permit udp host xxx host xxx eq isakmp
access-list 150 permit ip any 192.168.18.0 0.0.0.255
access-list 150 deny ip any any
priority-list 1 protocol ip high
dialer-list 1 protocol ip permit
route-map nonat permit 10
match ip address 110
Silver
Re: 1750 drops connection after hours
Any good logs from the router? How about errors in 'show interface eth0' or 'show controller eth0'?
xxxxxx#sh controller e0
PQUICC Ethernet unit 0 using SCC1, Microcode ver 4
Current station address 0004.dd0c.d3da, default address 8138.d0d8.80e5
idb at 0x810880D0, driver data structure at 0x81089E90
SCC Registers:
General [GSMR]=0x0:0x1088003C, Protocol-specific [PSMR]=0x80A
Events [SCCE]=0x0000, Mask [SCCM]=0x001F, Status [SCCS]=0x0002
Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0xD555
Interrupt Registers:
Config [CICR]=0x00365F80, Pending [CIPR]=0x8000C000
Mask [CIMR]=0x40200000, In-srv [CISR]=0x00000000
Command register [CR]=0x600
Port A [PADIR]=0x0000, [PAPAR]=0x0903
[PAODR]=0x0000, [PADAT]=0xF7FF
Port B [PBDIR]=0x0000100F, [PBPAR]=0x0000100E
[PBODR]=0x00000000, [PBDAT]=0x0000EDFC
Port C [PCDIR]=0x0000, [PCPAR]=0x0000
[PCSO]=0x0030, [PCDAT]=0x0FCC, [PCINT]=0x0000
wic_enet_regs_ptr->ctrl_reg is0xB5
SCC ETHERNET PARAMETER RAM (at 0xFF003C30)
CRC Preset [C_PRES]=0xFFFFFFFF, Mask [C_MASK]=0xDEBB20E3
Errors: CRC [CRCEC]=0, Alignment [ALEC]=0, Discards [DISFC]=0
PAD Char [PADS]=0x0
Retry Limit [RET_LIM]=15, Count [RET_CNT]=15
Frame Lengths: [MAXFLR]=1518, [MINFLR]=64
Max DMA Lengths: [MAXD1]=1518, [MAXD2]=1518
Group Address Filter [GADDRn]=0000:0000:0000:0100
Indiv Address Filter [IADDRn]=0000:0000:0000:0000
Physical Address [PADDR1]=DAD3.0CDD.0400
Last Address Set in Filter [TADDR]=CCCC.CC0C.0001
Persistence [P_Per]=0, Backoff Cnt [BOFF_CNT]=0
BD Pointers:
First Rx [RFBD]=0x0, First Tx [TFBD]=0x2318, Last Tx [TLBD]=0x2310
Receive Ring
rmd(FF002230): status 9000 length 72 address 1B00404
rmd(FF002238): status 9000 length 72 address 1AFF704
rmd(FF002240): status 9000 length 72 address 1AFEA04
rmd(FF002248): status 9000 length 72 address 1B04504
rmd(FF002250): status 9000 length 72 address 1B05884
rmd(FF002258): status 9000 length 72 address 1B07284
rmd(FF002260): status 9000 length 72 address 1B08604
rmd(FF002268): status 9000 length 72 address 1B00A84
rmd(FF002270): status 9000 length 72 address 1B09984
rmd(FF002278): status 9000 length 72 address 1B03184
rmd(FF002280): status 9000 length 72 address 1B06C04
rmd(FF002288): status 9000 length 72 address 1B01E04
rmd(FF002290): status 9000 length 72 address 1B03E84
rmd(FF002298): status 9000 length 72 address 1B08C84
rmd(FF0022A0): status 9000 length 40 address 1AFE384
rmd(FF0022A8): status B000 length 72 address 1B05204
Transmit Ring
tmd(FF0022B0): status 5C00 length 3C address 199B48A
tmd(FF0022B8): status 5C00 length 6E address 199C8E6
tmd(FF0022C0): status 5C00 length 6E address 199BF26
tmd(FF0022C8): status 5C00 length 6E address 199DFA6
tmd(FF0022D0): status 5C00 length 6E address 199C8E6
tmd(FF0022D8): status 5C00 length 6E address 199C8E6
tmd(FF0022E0): status 5C00 length 6E address 199C8E6
tmd(FF0022E8): status 5C00 length 6E address 199BF26
tmd(FF0022F0): status 5C00 length 286 address 1B0E9A6
tmd(FF0022F8): status 5C00 length 286 address 199E966
tmd(FF002300): status 5C00 length 286 address 199CF66
tmd(FF002308): status 5C00 length BE address 199E2E6
tmd(FF002310): status 5C00 length BE address 1B0E666
tmd(FF002318): status 5C00 length 286 address 199D5E6
tmd(FF002320): status 5C00 length 286 address 199BBE6
tmd(FF002328): status 7C00 length 6E address 199C8E6
0 missed datagrams, 0 overruns
0 transmitter underruns, 0 excessive collisions
0 single collisions, 0 multiple collisions
0 dma memory errors, 0 CRC errors
0 alignment errors, 0 runts, 0 giants
QUICC SCC specific errors:
0 buffer errors, 0 overflow errors
0 input aborts on late collisions
0 throttles, 0 enables
Silver
Show log on the router does it show that the E0 went down? Maybe the problem is not an interface problem. It can be some other thing such as IP conflict on E0 interface.
Let me know,
Also, look at sh ver -- it will give router uptime and the reason for the last reboot. Insure the router is staying up (or if it goes down, read the reason why).
xxxxx#sh int e0
Ethernet0 is up, line protocol is up
Hardware is PQUICC Ethernet, address is 0004.dd0c.d3da (bia 0004.dd0c.d3da)
Internet address is xxxxxxxxxx/29
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Half-duplex, 10BaseT
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5391270 packets input, 3720647055 bytes, 0 no buffer
Received 147866 broadcasts, 0 runts, 0 giants, 0 throttles
5753215 packets output, 1127870385 bytes, 0 underruns(0/0/0)
0 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
xxxxxxx#sh log
Syslog logging: disabled (0 messages dropped, 1 messages rate-limited, 310 flushes, 0 overruns)
Console logging: level debugging, 313 messages logged
Monitor logging: level debugging, 0 messages logged
Buffer logging: disabled
Logging Exception size (0 bytes)
Trap logging: disabled
The sh ver shows an uptime of forty weeks.
Thanks for the help guys.
Silver
Logging is disabled on your router. Enable logging so you can track what's going on the router. Use the command "logging buffered"
Let me know the logs after some days,
Can I just do a show log to view the logs?
134
