1811 Dual Wan Setup
Alright...I am trying to set up several 1811 routers I purchased a few weeks back, but I'm going nuts over this stuff. We are going to have 3 of these set up in 3 different locations, all VPN'd together with GRE tunnels for VOIP. 2 of these have a Data T1 (Eth0) and RoadRunner (eth1). I want to make it so that all normal traffic goes over the RR, but VPN needs to go over the T1. The T1 also needs to provide backup internet if RR goes down. So, yeah...below is my config. I've never worked on a Cisco before, so I'm confused to say the least. I only know how to use SDM to boot - anyone know of a good crash guide to IOS while I'm at it??? Let me know your opinions, good, bad, or ugly...gotta figure this stuff out.
BeginConfig:
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname RouterTwo
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.3.1 192.168.3.200
ip dhcp pool sdm-pool1
import all
network 192.168.3.0 255.255.255.0
dns-server 65.xxx.xxx.65 207.xxx.xxx.10
default-router 192.168.3.1
ip tcp synwait-time 10
no ip bootp server
ip domain name yomama.com
ip name-server 65.xxx.xxx.65
ip name-server 207.xxx.xxx.10
ip ssh time-out 60
ip ssh authentication-retries 2
interface FastEthernet0
description $ES_WAN$$FW_OUTSIDE$
ip address 207.xxx.xxx.204 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface FastEthernet1
description $ETH-WAN$
ip address 24.xxx.xxx.188 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$$ES_LAN$$FW_INSIDE$
ip address 192.168.3.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
interface Async1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation slip
ip route 0.0.0.0 0.0.0.0 207.xxx.xxx.201
ip route 0.0.0.0 0.0.0.0 24.xxx.xxx.185 2
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet0 overload
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.3.0 0.0.0.255
no cdp run
Re: 1811 Dual Wan Setup
There is no VPN configuration. Try running through the VPN wizard. I looked at it once and I'm pretty sure there is a GRE setup in there somewhere.
All I see is that its being configured with FE Interfaces. There is NO VPN config of whatsoever!
Please provide more details, and we would be glad to help you setup the VPNs.
Wilson Samuel
Im looking into a similar setup, but I would like to know how to configure NAT overload in this situation. how would you go about configuring NAT to overload based on the egress interface?
Also, what if one of the interfaces was DHCP? you would not be able to specify a default route next-hop (you would have to use ip route 0.0.0.0 0.0.0.0 dhcp?), and you would also not have the static IP for nat (you would have to overload the interface).
Does anyone have a sample config for this?
Silver
Can you elaborate more on the question of "on egress interface: ? Do you mean NAT one inside address to multiple outside address ?
NAT overload is used on the Port address translation.
If it is a DHCP address, you can use interface as the next-hop instead of the IP address.
e.g. ip route 0.0.0.0 0.0.0.0 dialer 0
Check here for NAT examples :
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
Hope this helps.
Hopefully i am not making this harder than it should be. let me clarify a bit.
with a dual wan, dual ISP setup, you would have:
ethernet0
ip address 99.99.99.254
ethernet1
ip address dhcp
and LAN:
vlan1
ip address 192.168.1.1
for default routes, we could have something like..
ip route 0.0.0.0 0.0.0.0 99.99.99.1 100
ip route 0.0.0.0 0.0.0.0 (dhcp or ethernet1, not sure which?) 150
so that should take care of interfaces and routing. now what about PAT? do we just create two nat entries?
ip nat inside source list 1 ethernet0 overload
ip nat inside source list 1 ethernet1 overload
would this correctly PAT the addresses, say if ethernet0 goes down, ethernet1 will take over?
I saw another post on NetPro, where a user had a dual wan setup such as this, and when the system built the NAT entries, and the primary link was up, everything was ok. but when the primary link failed, it would not remove and recreate the NAT map for the secondary link.
Do you see what i am getting at? hope this helps.
Silver
As mentioned, the second static route should be :
ip route 0.0.0.0 0.0.0.0 ethernet1 150
The overload command is correct. However, in your case, both WAN are using Ethernet, if the any of the ISP network down, the Ethernet may now down, so the next-hop in your routers will still be active and not able to failover to another link. Therefore, you may require to deploy the object tracking to overcome this issue. Check below :
http://www.cisco.com/en/US/products/ps6441/products_configuration_guide_chapter09186a0080774e79.html
Hope this helps.
Cool, I think i'm on the right track now.
Here is the config guide for static routing object tracking: http://www.cisco.com/en/US/products/sw/iosswrel/ps5413/products_feature_guide09186a00801d862d.html#wp1051155
And here is the basic config for my example:
interface ethernet 0/0
description primary-link
ip dhcp client route track 123
ip address dhcp
interface serial 0
description backup-link
ip address 10.2.2.2 255.0.0.0
ip sla monitor 1
type echo protocol ipIcmpEcho 172.16.23.7
timeout 1000
frequency 3
threshold 2
ip sla monitor schedule 1 life forever start-time now
track 123 rtr 1 reachability
access list 101 permit icmp any host 172.16.23.7 echo
route map MY-LOCAL-POLICY permit 10
match ip address 101
set ip next-hop dynamic dhcp
ip local policy route-map MY-LOCAL-POLICY
ip route 0.0.0.0 0.0.0.0 10.2.2.125 254
Thanks for the help!
Silver
The config. looks like, please advise the result if you carried the test. :)
317
