Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
1811 want and switch port connection
can i put all 8 switch ports in one vlan. after assigning IP, on interface vlan 10 i'll give ip 10.1.1.1 . can i use "ip nat inside" on interface vlan 1 ??
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: 1811 want and switch port connection
Usman,
Your original post made me believe you understood the configuration.
Say, you want ports 1-4 to be in Vlan 20(inside Vlan) and ports 5-8 in Vlan 10 (outside Vlan)
1) Create the Vlans in the switch database
Rack1SW1#vlan database
Rack1SW1(vlan)#vlan 10 name outside
VLAN 10 added:
Rack1SW1(vlan)#vlan 20 name inside
VLAN 20 added:
2) Assign the ports to their respective Vlans:
Rack1SW1(config)#int ran f1/1 - 4
Rack1SW1(config-if-range)#switchport access vlan 20
Rack1SW1(config)#int ran f1/5 - 8
Rack1SW1(config-if-range)#switchport access vlan 10
3) Assign the IP address under the SVIs
Rack1SW1(config)#int vlan 10
Rack1SW1(config-if)#ip add 10.10.10.1 255.255.255.0
Rack1SW1(config-if)#int vlan 20
Rack1SW1(config-if)#ip add 10.20.20.1 255.255.255.0
4) Then configure NAT as you would on a regular router but place the ip nat inside under interface vlan 20 and ip nat outside under interface vlan 10
HTH,
__
Edison.
Please rate helpful posts
Hi Usman,
Yes, you sure can.
Please see the following link for more configuration info:
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_configuration_example09186a0080810449.shtml
HTH,
__
Edison.
Thanks for your reply..
i could not find nat commands that works with built in switch ports. in 1811 / 1812
these are not routed ports.. right ?
usman
No, they aren't routed ports.
You need to place the NAT under the SVIs (Switch Virtual Interface).
HTH,
__
Edison.
thank you so much HTH,
can i get some specific example of that.. as i have to quote the same router some where .. and i have to prove that it will work that way..
thanks a lot
usman
! 1. define vlan
vlan 10
name intern
! 2. put switchports into vlan
int fas 2
switchport mode access
no shutdown
! same for fas 3... fas 9
! fas 0 and fas 1 are real ethernet ports
! 3. configure ip
int vlan 10
ip address 10.1.1.1 255.255.255.0
no shutdown
ip nat inside
Yes, that also works with the default-vlan 1,
where initially all 8 switches ports
are members of.
Usman,
VLAN 10 added:
VLAN 20 added:
HTH,
__
Edison.
wow..
thanks a lot.. it worked..
Usman
760
