Community Member
1811 will not upgrade to latest IOS
I have five 1811 routers that will not upgrade to the latest IOS version c181x-adventerprisek9-mz.124-24.T8.bin
They all have this weird IOS version "PCBU_WIRELESS_BASE_POINT" installed but none are wireless Wifi or 3/4g (if this is what they are referring to)
Store_10601#sh ver
Cisco IOS Software, C181X Software (C181X-ADVENTERPRISEK9-M), Version 12.3(weekly.V123_8_YI_THROTTLE050620) NIGHTLY BUILD, synced to pcbu_wireless PCBU_WIRELESS_BASE_POINT_FOR_V123_8_YI_THROTTLE
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Mon 20-Jun-05 23:45 by philuu
Store_10601 uptime is 1 hour, 8 minutes
System returned to ROM by reload at 12:34:16 CST Wed Apr 23 2014
System restarted at 12:35:04 CST Wed Apr 23 2014
System image file is "flash:c181x-adventerprisek9-mz.050620
I have set the boot system flash as follows and as I said, it always rolls over to the original version.
boot-start-marker
boot system flash c181x-adventerprisek9-mz.124-24.T8.bin
boot system flash c181x-adventerprisek9-mz.050620
boot system flash
boot-end-marker
Config register is as follows
Config reg is 0x2102
I also did a verify on the new file and the hash checks out
...Done!
Embedded Hash   MD5 : 1DDCA3043480EFE57E91EEB7C008F213
Computed Hash   MD5 : 1DDCA3043480EFE57E91EEB7C008F213
CCO Hash        MD5 : EDC41D3DAEA62B5805DE7CA17B6EFF1B
Any Ideas???
Everyone's tags (1)
What is the output of "show
What is the output of "show bootvar" please?
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Community Member
Store_10601#show b?    backup
Store_10601#show b?
backup  bgp  bridge  buffers
Store_10601#show bootvar
% Invalid input detected at '^' marker.
Store_10601#
Hmm. Okay - I take it you did
Hmm. Okay - I take it you did the reboot and it came back with the same IOS code... have you done this?
conf t
no boot system flash c181x-adventerprisek9-mz.050620
end
copy run start
Then reload?
Community Member
Yes, see original post
Hall of Fame Super Gold
"sh bootvar" won't work on
"sh bootvar" won't work on some routers.  You may need to post the output to the command "sh run | b oot-start-marker".
Community Member
The version I tried to load
The version I tried to load is NOW this since I changed it just in case the other had some quirk why it would not load. This wont load either.
Store_10601#sh run | b boot-start-marker
boot-start-marker
boot system flash c181x-adventerprisek9-mz.124-15.T7.bin
boot system flash
boot-end-marker
Your boot variable string is
Your boot variable string is an incorrect syntax.
Try this:
config t
no boot system flash c181x-adventerprisek9-mz.124-15.T7.bin
boot system flash:c181x-adventerprisek9-mz.124-15.T7.bin
end
wr
reload
Can you also post the complete output to the command "sh version".  I want to check if your router has enough DRAM and flash to support this IOS.  (256/64).
339
