1811 with dual port WIC + config
I have installed a dual port WIC in slot 0 on a 1811. The problem i experince is only on WIC port 1 (port 0 has no problems).
on port 1 on the WIC card, when i connect the cable from the NT box (ISDN PRI) the controller E1 is going up while reporting "(AIS detected), then the link is going up and then the protocol is going up. Then 5 sec after the protocol go down again.
I have tried both WIC ports on the same NT box and both WIC ports on another NT box and there is always a problem with WIC port 1 on each NT box and no problem with port 0. When i began working on this router it had a working WIC installed with one port, i changed the WIC with a dual port WIC to support an exstra WAN line and added the new controller and serial interface and not much else. as far as i can see the naming of the new controller and interface is correct and well, i leaning towards a software or hardware error. please let me know what you think.
Here is the configuration, i have removed vty,console and line info and some other non relevant info to shorten the file.
Current configuration : 1594 bytes
version 12.4
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
resource policy
no network-clock-participate wic 0
ip subnet-zero
ip cef
ip domain name yourdomain.com
isdn switch-type primary-net5
controller E1 0/0/0
channel-group 0 unframed
controller E1 0/0/1
interface Loopback1
ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
ip address 192.x.x.1 255.255.0.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:0
ip address 192.168.20.1 255.255.255.0
encapsulation ppp
interface Serial0/0/1:0
ip address 192.168.21.1 255.255.255.0
encapsulation ppp
ip classless
ip route 154.x.x.x.255.0.0 Serial0/0/0:0
ip route 160.x.x.x.255.0.0 192.168.21.2
ip route 192.x.x.x.255.0.0 FastEthernet0/0
ip route 192.168.1.0 255.255.255.0 Serial0/0/0:0
ip route 192.168.10.0 255.255.255.0 Serial0/0/0:0
ip http server
ip http authentication local
ip http timeout-policy idle 5 life 86400 requests 10000
control-plane
1 REPLY
Bronze
Re: 1811 with dual port WIC + config
Try out the tests mentioned the document to find out whether the issue is with the router or telco.
http://www.cisco.com/warp/public/471/hard_loopback.html
124
