07-16-2008 06:35 AM - edited 03-03-2019 10:45 PM
I'm using a little 1811W to test multicast routing.
There are 2 VLANs configured (3 & 4) attached to 2 BVI interfaces. There are separate wireless SSIDs attached to each VLAN. There is a Loopback, which is configured as the static RP address. PIM sparse-dense is configured on the 2 BVIs and the Loopback. IGMP snooping is enabled globally.
When using VLC on VLAN 3 to stream audio or video to 239.255.0.1, I can use VLC player to receive the multicast stream on the same VLAN no problem, but on the other VLAN (4) it works only over wireless, and if I use a VLC wired client on VLAN 4 I receive nothing.
With the wireless client, ip mroute shows the outgoing interface correctly, and all works fine. But with a wired client, there is no outgoing interface (Null OIL).
The wired client uses one of the 8 built-in switch ports BTW, with "switchport access vlan 4/switchport mode access" configured.
Short of posting the full config, does anyone know what may be causing this problem?
IOS version is 12.4(15)T6.
07-22-2008 02:07 PM
Here is the URL for the configuration for the Cisco 1811W follow the URL which will help you :
07-24-2008 03:33 AM
Thanks for your reply, but neither of those URLs really seem to address the specific problem I have. And in any case, I'm not using the IOS firewall described in your URL, but the zone-based policy firewall. All the interfaces over which I'm trying to route multicast are in the same zone.
