1841 isr Router SDM problem
hi
i have got a 1841 isr router having SDM.i am having a strange problem, whenever i configure an accesslist on any interface it starts blocking my telnet connection from outside. i tried to apply an acl having permit ip any any on my outside interface then also it starts blocking my ssh or telnet connection.
Hall of Fame Super Silver
Re: 1841 isr Router SDM problem
That does seem unusual. Perhaps you would post the config of the router (masking any sensitive information). This might help us to figure out what is going on.
Rick
hi
the config of the router is given below
sh run
Building configuration...
Current configuration : 4714 bytes
version 12.3
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret xxxx
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
--More-- mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip ips deny-action ips-interface
ip domain name yourdomain.com
ip name-server 203.x.x.30
ip name-server 202.x.x.50
vpdn enable
vpdn ip udp ignore checksum
vpdn-group WindowsVpn
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
vpdn-group vpnWindows
--More-- !
no ftp-server write-enable
crypto pki trustpoint TP-self-signed-2572555141
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2572555141
revocation-check none
rsakeypair TP-self-signed-2572555141
crypto pki certificate chain TP-self-signed-2572555141
certificate self-signed 01
17806F5D 3656E40B A59F3BC9 4824819F 139F4DF6 757390A6
username cisco privilege 15 password xxx
crypto keyring WindowsVpn
pre-shared-key address 0.0.0.0 0.0.0.0 key cisco
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
lifetime 3600
crypto isakmp keepalive 3600
no crypto isakmp ccm
crypto ipsec security-association lifetime seconds 600
crypto ipsec transform-set divita esp-3des esp-sha-hmac
crypto dynamic-map DYN_MAP 10
set transform-set divita
crypto map CRYP_MAP 6000 ipsec-isakmp dynamic DYN_MAP
interface Loopback0
no ip address
interface FastEthernet0/0
description LINT TO INTERNET
ip address 61.17.x.x.x.255.0
ip nat outside
ip virtual-reassembly
shutdown
duplex auto
interface FastEthernet0/1
description LINK TO LAN
ip address 10.129.149.80 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered Loopback0
peer default ip address pool POOL
ppp mtu adaptive
ppp authentication chap ms-chap
ip local pool POOL 172.16.1.2 172.16.1.254
ip classless
ip route 0.0.0.0 0.0.0.0 61.17.249.1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit any
control-plane
banner login ^C
line con 0
login local
line aux 0
line vty 0 4
password cisco
login
transport input telnet
line vty 5 15
privilege level 15
login local
transport input none
warm-reboot
end
whenever i remove the nating i am able to telnet from outside and able to connect thrgh pptp. but when i put nating i cant telnet and cant connect thrgh pptp.
The original post indicated that the problem was that if you put an access list on an interface it blocked your telnet. This post indicates that the problem is that if you enable NAT it blocks telnet. Those are significantly different symptoms.
I see that FastEthernet0/0 is shutdown. Do you have the same symptoms when it is no shut? Since that interface is the address to which you NAT I can believe that it might be a problem if it was shutdown?
I am not sure that it is related, but I notice something else that seems not right. The virtual template interface uses ip unnumbered:
but the loopback 0 interface has no IP address.
Rick
hi dippu
as per ur configuration there is only one mistake foudn thats with ur standard access-list just u modify that now current acls is like this acess-list 1 permit ip any u just remove this and add like this access-list 1 permit 192.168.1.0 0.0.0.255
thanku
rsreddy
thank you sir
416
