1841 PTP issues
Joe Link
Hi  everyone,
     Kind of a noob so go slow. I am trying to configure a PTP with 2 1841's ver 12.4 and I can't tell if my config is the issue or the ISP. I am bonding 2 t-1's with serial interfaces. Any help is appreciated.
Router1:
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip bootp server
no ip domain lookup
ip domain name dm1.com
multilink virtual-template 1
username *
interface Null0
no ip unreachables
interface Loopback0
ip address 172.90.0.2 255.255.255.252
interface FastEthernet0/0
description Internal Interface
ip address 192.168.20.4 255.255.255.128
speed 100
full-duplex
no cdp enable
interface FastEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
shutdown
duplex auto
speed auto
no cdp enable
interface Serial0/0/0
description WLYbor PTP1
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
interface Serial0/1/0
description WLYbor PTP2
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
interface Virtual-Template1
ip unnumbered Loopback0
ppp authentication chap
ppp multilink
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.20.1
ip route 10.0.0.0 255.255.255.0 172.90.0.1
ip route 192.168.20.0 255.255.255.0 FastEthernet0/0
no ip http server
no ip http secure-server
Router 2:
no mmi pvc
ip subnet-zero
ip cef
no ip domain lookup
username *
interface Loopback0
ip address 172.90.0.1 255.255.255.252
description ColoLAN
ip address 10.0.0.253 255.255.255.0
duplex auto
speed auto
ip address 172.40.0.2 255.255.255.252
speed 100
full-duplex
no ip address
encapsulation ppp
no fair-queue
pulse-time 1
no cdp enable
ppp multilink
no ip address
encapsulation ppp
no fair-queue
pulse-time 1
no cdp enable
ppp multilink
ppp multilink
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.254
ip route 10.0.0.0 255.255.255.0 FastEthernet0/0
ip route 10.0.20.0 255.255.255.0 172.40.0.1
ip route 192.168.20.0 255.255.255.0 172.90.0.2
Peter Paluch
Hi Joe,
I do not quite understand if you are trying to bond these two routers together, or if you want to bond two T1's and the second end of the multilink bundle is the ISP itself.
Nevertheless, your configuration is more relevant to a PPP Multilink access concentrator than to just two routers connected via multiple parallel PPP links. You do not need the Virtual-Template interface nor the multilink virtual-template 1 command. A common PPP Multilink configuration of two serial interfaces commonly looks as follows:
encapsulation ppp
ppp multilink group 1
no shutdown
interface Serial0/0/1
encapsulation ppp
no shutdown
interface Multilink1
encapsulation ppp
ip address negotiated ! or static IP address
! ... remaining configuration
Nothing more is needed to make a PPP Multilink work so I suggest removing all additional commands from your configuration you have currently used. The opposite side should be configured in the same way. Until you get the basic multilink running, I suggest avoiding the authentication (if not required by your ISP). Issues with authentication may complicate troubleshooting your current configuration, so let's try to avoid it at the beginning.
In addition, I see that both your routers have a static route pointing out the Fa0/0 interface. Avoid this style of configuring static routes. It is appropriate only for point-to-point interfaces and on Ethernet networks, it may cause issues (don't want to go into details now). Replace these static routes with routes specified by the next-hop IP address instead of egress interface.
Please keep me posted, and be sure to include the configuration of the routers once you change it according to the suggestion above. Thanks!
Best regards,
Peter
Peter Paluch
Hi Joe,
encapsulation ppp
no shutdown
encapsulation ppp
no shutdown
encapsulation ppp
Best regards,
Peter
I made the changes you suggested and it is working. Thanks here are the configs.
Router1:
no mmi pvc
ip subnet-zero
ip cef
no ip domain lookup
username
ppp multilink
description ColoLAN
duplex auto
speed auto
speed 100
full-duplex
no ip address
encapsulation ppp
no fair-queue
no cdp enable
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ip classless
Router 2:
no mmi pvc
ip subnet-zero
ip cef
no ip bootp server
no ip domain lookup
username
interface Null0
no ip unreachables
no cdp enable
ppp multilink
speed 100
full-duplex
no cdp enable
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
shutdown
duplex auto
speed auto
no cdp enable
no ip address
encapsulation ppp
no fair-queue
no cdp enable
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ip classless
