01-16-2006 03:01 AM - edited 03-03-2019 11:28 AM
I am hoping someone can help me with the following configuration. This may be an elementary configuration but I am just really getting started working with Cisco routing so any help would be much appreciated. I have I have a Cisco 1841 router with 2 WIC T1 CSU\DSU cards installed. I have two internal networks, one connected to Ethernet 0/0 and one connected to Ethernet 0/1 on the 1841. I want all traffic leaving the network connected to Ethernet 0/0 only to be routed to the T1 connected to the wic on Serial 0/0 and all the traffic coming from the network connected to Ethernet 0/1 only to be routed to the T1 connect to the wic on Serial 0/1. Please advise on proper configuration to make this work and\or documentation on a configuration like this. I really appreciate any help.
JPS
01-16-2006 03:08 AM
What you want to do can be achieved by the use of policy routing. Please have a look at the following URL to learn it's features:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009481d.shtml
Leo
01-16-2006 03:08 AM
You need to use policy-based routing to accomplish this. Try the following configuration:
int ethernet0/0
ip policy route-map PBR1
int ethernet0/1
ip policy route-map PBR2
policy-map PBR1
set interface serial0/0:
policy-map PBR2
set interface serial0/1:
Replace channel-group with your actual channel-group numbers.
Hope that helps - pls rate the post if it does.
Paresh.
