Community Member
1841 router with WIC 1ADSL
Pros,
The new 1841 router with the default image c1841-ipbase-mz.124-6.XE3.bin loaded not coming up with ADSL WIC installed on any slot of the router. It keeps on rebooting. Pls see the attached file for the boot sequence.
Even after i loaded with the new image c1841-ipbasek9-mz.124-24.T.bin, the same problem.
What is the work around to solve this issue?
swami
Hall of Fame Super Silver
Re: 1841 router with WIC 1ADSL
Hello Arumugasamy,
you need to upgrade to an IOS image that supports the ADSL WIC
try with
c1841-ipbasek9-mz.124-15.T8.bin
that FN declares support it
see
www.cisco.com/go/fn
Hope to help
Giuseppe
Community Member
Try to upgreade the IOS to advanceservice 12.4.This image will support the ADSL card with advance security " IOS filter "
Community Member
I tried 4 ios images. This card i tried with another router with the same problem. But when i used another WIC adsl with this router, it is working. So I believe that the WIC is defective.
Let me wait and update you
swami
Hall of Fame Super Gold
With the suspected faulted WIC card, during the bootup, are there any error messages?
587
