03-24-2017 12:30 AM - edited 03-05-2019 08:14 AM
Router 1905 crashing even we have upgrade/degrade IOS. Please find following information and suggest further :
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.4(3)M7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 02-Feb-17 21:04 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Installed image archive
Cisco CISCO1905/K9 (revision 1.0) with 225280K/36864K bytes of memory.
Processor board ID FGL170122BY
6 Gigabit Ethernet interfaces
1 Serial(sync/async) interface
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
249840K bytes of USB Flash usbflash0 (Read/Write)
Warning: The cli will be deprecated soon
'tacacs-server host 151.200.10.130'
Please move to 'tacacs server <name>' CLI
SYSTEM INIT: INSUFFICIENT MEMORY TO BOOT THE IMAGE!
%Software-forced reload
09:41:58 IST Tue Mar 21 2017: Breakpoint exception, CPU signal 23, PC = 0x21D889A4
03-24-2017 12:53 AM
Re-load the IOS via ROMmon. I suspect the IOS could be corrupt.
03-24-2017 01:10 AM
Hi Leo,
We have re-loaded and upgrade same IOS again after format flash. But router was working with "c1900-universalk9-mz.SPA.151-2.T5.bin" .
03-24-2017 01:15 AM
But if the IOS file in your TFTP server is already corrupt, what's the use?
03-24-2017 04:56 AM
We have downloaded fresh again and then upgrade in two 1905 router. But one of them crashing and another one show high memory issue.
Version 15.4(3)M7 is latest version, is it possible it used more memory to process that why the router crashing.
03-24-2017 05:19 AM
Verify the IOS hardware or memory requirements before to upgrade the device, it can be verified on the cisco website.
The IOS 15.4(3) requires:
DRAM 256 MB
Flash 256 MB
If your device is not created with this hardware specs the IOS will not be supported and it will not be loaded and error messages will be displayed.
Other IOS with less requirements could be used.
Hope it is useful
03-24-2017 05:43 AM
That was already verified, both DRAM/Flash are compatible
1 terminal line
Process Memory with : Version 15.4(3)M7:
Dariyapur#sh ver | in fl
System image file is "flash:c1900-universalk9-mz.SPA.154-3.M7.bin"
Dariyapur#sh proc me
Dariyapur#sh proc memory
Processor Pool Total: 60671868 Used: 50246744 Free: 10425124
I/O Pool Total: 37748736 Used: 14483824 Free: 23264912
Process Memory with : Version 15.1(2)T5:
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(2)T5, RELEASE SOFTWARE (fc1)
System image file is "flash:c1900-universalk9-mz.SPA.151-2.T5.bin"
Technology Package License Information for Module:'c1900'
Dariyapur#sh processes mem
Processor Pool Total: 110867872 Used: 33825548 Free: 77042324
I/O Pool Total: 37748736 Used: 14426848 Free: 23321888
03-24-2017 02:49 PM
Remove all NM/NME or HWIC/EHWIC. Reboot the router and post the entire boot-up process.
03-27-2017 03:03 AM
We are working on the same, will update you..
04-09-2017 10:47 PM
Please find boot-up process of the router. The router having on board HWIC-1T. It still showing very less free memory in process:
System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Copyright (c) 2012 by cisco Systems, Inc.
Total memory size = 256 MB
CISCO1905/K9 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC disabled
Readonly ROMMON initialized
program load complete, entry point: 0x80903000, size: 0x4c4a0
IOS Image Load Test
___________________
Digitally Signed Release Software
program load complete, entry point: 0x81000000, size: 0x48294f4
Self decompressing the image : ########################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################## [OK]
Smart Init is enabled
smart init is sizing iomem
TYPE MEMORY_REQ
HWIC Slot 0 0x00200000
Onboard devices &
buffer pools 0x01E8F000
TOTAL: 0x0208F000
Rounded IOMEM up to: 36MB.
Using 14 percent iomem. [36MB/256MB]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.4(3)M6a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 26-Sep-16 07:35 by prod_rel_team
export@cisco.com.
Processor board ID FGL170121ED
2 Gigabit Ethernet interfaces
1 terminal line
Press RETURN to get started!
*Jan 2 00:00:03.063: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c1900 Next reboot level = ipbasek9 and License = ipbasek9
*Jan 2 00:00:03.275: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c1900 Next reboot level = securityk9 and License = securityk9
*Apr 10 04:38:07.127: c3600_scp_set_dstaddr2_idb(184)add = 80 name is Embedded-Service-Engine0/0
*Apr 10 04:38:16.143: %CTS-6-ENV_DATA_START_STATE: Environment Data Download in start state
*Apr 10 04:38:19.151: %PA-3-PA_INIT_FAILED: Performance Agent failed to initialize (Missing Data License)
*Apr 10 04:38:19.179: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Initialized
*Apr 10 04:38:19.183: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Enabled
*Apr 10 04:38:24.223: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
*Apr 10 04:38:24.223: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
*Apr 10 04:38:24.223: %LINK-3-UPDOWN: Interface Serial0/0/0, changed state to down
*Apr 10 04:38:25.223: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
*Apr 10 04:38:25.223: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
*Apr 10 04:38:25.227: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0, changed state to down
*Apr 10 04:38:29.347: %USBFLASH-5-CHANGE: usbflash0 has been inserted!
*Apr 10 04:38:31.815: %SYS-5-CONFIG_I: Configured from memory by console
*Apr 10 04:38:33.775: %LINK-5-CHANGED: Interface Embedded-Service-Engine0/0, changed state to administratively down
*Apr 10 04:38:33.775: %LINK-5-CHANGED: Interface GigabitEthernet0/1, changed state to administratively down
*Apr 10 04:38:33.827: %LINK-5-CHANGED: Interface Serial0/0/0, changed state to administratively down
*Apr 10 04:38:34.807: %LINEPROTO-5-UPDOWN: Line protocol on Interface Embedded-Service-Engine0/0, changed state to down
*Apr 10 04:38:35.375: %SYS-5-RESTART: System restarted --
*Apr 10 04:38:36.051: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Apr 10 04:38:36.051: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
Router>
Router>
Router>
Router>
Router>
Router>en
Router#
Router#sh ver
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Router uptime is 2 minutes
System image file is "usbflash0:c1900-universalk9-mz.SPA.154-3.M6a.bin"
Last reload type: Normal Reload
Last reload reason: power-on
--More-- to comply with U.S. and local laws, return this product immediately.
export@cisco.com.
1 terminal line
License Info:
License UDI:
--More-- -------------------------------------------------
Device# PID SN
*1 CISCO1905/K9 FGL170121ED
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
data None None None
NtwkEss None None None
Configuration register
------------------ show memory statistics ------------------
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 2B08E8A0 60662780 43195892 17466888 2840248 14959332
I/O DC00000 37748736 14497672 23251064 23212760 23209596
------------------ show process memory ------------------
Processor Pool Total: 60662780 Used: 43194968 Free: 17467812
I/O Pool Total: 37748736 Used: 14497632 Free: 2325110
04-09-2017 11:00 PM
Please find boot-up process for router. The router having on board HWIC -1T. We have downgrade IOS but it still showing very less free memory.
IOS Image Load Test
___________________
TYPE MEMORY_REQ
Onboard devices &
TOTAL: 0x0208F000
cisco Systems, Inc.
export@cisco.com.
1 terminal line
Router>
Router>
Router>
Router>
Router>
Router>en
Router#
Router#sh ver
export@cisco.com.
1 terminal line
License Info:
License UDI:
Device# PID SN
data None None None
I/O Pool Total: 37748736 Used: 14497632 Free: 23251104
04-10-2017 02:01 AM
In another some series router after upgrade to c1900-universalk9-mz.SPA.155-3.M5.BIN, now it is showing 512 MB of DRAM/256 Mb of flash:
Cisco CISCO1905/K9 (revision 1.0) with 487424K/36864K bytes of memory.
1 terminal line
Booting logs:
IOS Image Load Test
___________________
program load complete, entry point: 0x81000000, size: 0x4c0464c
Self decompressing the image : #################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################### [OK]
TYPE MEMORY_REQ
Onboard devices &
TOTAL: 0x0208F000
UPGRADING TO 512MB. RELOADING........
Total memory size = 512 MB
CISCO1905/K9 platform with 524288 Kbytes of main memory
IOS Image Load Test
___________________
TYPE MEMORY_REQ
Onboard devices &
TOTAL: 0x0208F000
Using 7 percent iomem. [36MB/512MB]
cisco Systems, Inc.
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.5(3)M5, RELEASE SOFTWARE (fc1)
Compiled Wed 25-Jan-17 02:48 by prod_rel_team
export@cisco.com.
1 terminal line
08-27-2018 05:28 PM
Thanks for your suggestion, i am having trouble upgrating from c1900-universalk9-mz.SPA.151-4.M4.bin to c1900-universalk9-mz.SPA.157-3.M2.bin UPGRADING TO 512MB. RELOADING........ and reboot again in a loop fashion, in the router 1905 we have 2 modules HWIC-1T and EHWIC-4ESG, when i remove EHWIC-4ESG the router upgrade to 512MB and start normal, then i install again EHWIC-4ESG and the router start normal.
Thanks guys,
