11-01-2013 04:00 AM - edited 03-04-2019 09:28 PM
I'm having issues with a 1921 and a new 4G card.
Below is the running config, show cellular and debug. The SP is EE in the UK, the APN is supposed to be everywhere, eesecure is the user and the password is also set (although not shown). The SP has confirmed the SIM is fine and the profile is correct. Apart from that they are not willing to help.
Can't see what is wrong here, any ideas? Anything else I can check?
Chris
Router#sh cellular 0/0/0 all
Hardware Information
Modem Firmware Version = SWI9200X_03.05.19.04
Modem Firmware built = 2012/09/17 17:57:14
Hardware Version = 10
International Mobile Subscriber Identity (IMSI) = 23404100839842
International Mobile Equipment Identity (IMEI) = 359470040067474
Integrated Circuit Card ID (ICCID) = 8944302751624005845
Mobile Subscriber International Subscriber
IDentity Number (MSISDN) = 07947586729
Profile Information
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = everywhere
Authentication = Unknown
Username: eesecure
Password:
* - Default profile
Data Connection Information
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = INACTIVE
Inactivity Reason = Unknown
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current Service Status = Normal
Current Service = Packet switched
Current Roaming Status = Home
Network Selection Mode = Automatic
Mobile Country Code (MCC) = 234
Mobile Network Code (MNC) = 30
Packet switch domain(PS) state = Attached
Registration(EMM) state = Registered
Radio Information
Radio power mode = ON
Current RSSI = -75 dBm
LTE Technology Preference = AUTO
LTE Technology Selected = LTE
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of CHV1 Retries remaining = 3
Error Information
This command is not supported on 4G modems.
Modem Crashdump Information
Modem crashdump logging: off
Router#
Router#sh run
Building configuration...
Current configuration : 1787 bytes
! Last configuration change at 10:33:53 UTC Fri Nov 1 2013
version 15.2
hostname Router
boot-start-marker
boot-end-marker
enable secret 4 eaOP83n/Avy2EAs2tg7JbhLCX5T8h39E3GwBeTDW5sY
no aaa new-model
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 60 "OK"
controller Cellular 0/0
interface Loopback0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.10.10.10 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Cellular0/0/0
ip address negotiated
ip nat outside
encapsulation slip
dialer in-band
dialer idle-timeout 60
dialer string lte
dialer-group 1
async mode interactive
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Cellular0/0/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
dialer-list 1 protocol ip permit
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 0/0/0
script dialer lte
modem InOut
no exec
transport input all
transport output all
rxspeed 100000000
txspeed 50000000
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Router#
Router#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
*Nov 1 10:47:18.059: Ce0/0/0 DDR: place call
*Nov 1 10:47:18.059: Ce0/0/0 DDR: Dialing cause ip (s=192.168.1.1, d=8.8.8.8)
*Nov 1 10:47:18.059: Ce0/0/0 DDR: Attempting to dial lte
*Nov 1 10:47:18.059: CHAT0/0/0: Attempting async line dialer script
*Nov 1 10:47:18.059: CHAT0/0/0: Dialing using Modem script: lte & System script: none
*Nov 1 10:47:18.059: CHAT0/0/0: process started
*Nov 1 10:47:18.059: CHAT0/0/0: Asserting DTR
*Nov 1 10:47:18.059: CHAT0/0/0: Chat script lte started
*Nov 1 1.0:47:18.059: CHAT0/0/0: Sending string: AT!CALL
*Nov 1 10:47:18.059: CHAT0/0/0: Expecting string: OK....
Success rate is 0 percent (0/5)
Router#
*Nov 1 10:48:18.059: CHAT0/0/0: Timeout expecting: OK
*Nov 1 10:48:18.059: CHAT0/0/0: Chat script lte finished, status = Connection timed out; remote host not responding
*Nov 1 10:48:18.059: Ce0/0/0 DDR: disconnecting call
*Nov 1 10:48:33.059: Ce0/0/0 DDR: re-enable timeout
Router#
Router#
Router#
Solved! Go to Solution.
11-07-2013 06:23 AM
It's a bug
basically you need to reset the modem after a reboot.
so I entered
test cellular 0 modem-power-cycle
After this the unit will connect until the unit is rebooted/powercycled.
11-01-2013 06:06 AM
This line of your output caught my attention
I am not clear where the source address of 192.168.1.1 came from. Is that the address learned by the cellular? If not what is it?
Rick
11-01-2013 06:45 AM
It's the IP of loopback 0.
I'm not expecting that to ping (it's a RFC 1918 address) but the cellular interface should come up.
At this point the cellular interface has not learned an IP.
See
Router#sh ip int br | inc Cell
Cellular0/0/0 unassigned YES NVRAM up up
Cellular0/0/1 unassigned YES unset down down
Cellular0/0/2 unassigned YES unset down down
Cellular0/0/3 unassigned YES unset down down
Router#sh int cell 0/0/0
Cellular0/0/0 is up (spoofing), line protocol is up (spoofing)
Hardware is 4G WWAN EHWIC - Global Multimode LTE/DC-HSPA+/HSPA+/HSPA/UMTS/EDGE/GPRS
Internet address will be assigned dynamically by the network
MTU 1500 bytes, BW 9 Kbit/sec, DLY 100000 usec,
Encapsulation SLIP, loopback not set
Keepalive not supported
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/10 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 unknown protocol drops
0 carrier transitions
DCD=down DSR=down DTR=up RTS=up CTS=up
Router#
11-01-2013 07:17 AM
I've also tried a 3G card on another provider (O2) changed the profile details accordingly and got pretty much teh same result. I have got a little more debug...
Router#debug cellular 0/0/0 messages data
DATA debugging is on
Router#debug cellular 0/0/0 messages call
Router#debug cellular 0/0/0 messages callcontrol
CALLCONTROL debugging is on
Router#debug cellular 0/0/0 messages async
ASYNC debugging is on
Router#debug chat]
% Invalid input detected at '^' marker.
Router#debug chat
Chat scripts activity debugging is on
Router#ping 8.8.8.8
*Nov 1 13:59:23.855: CHAT0/0/0: Attempting async line dialer script
*Nov 1 13:59:23.855: CHAT0/0/0: Dialing using Modem script: lte & System script: none
*Nov 1 13:59:23.855: CHAT0/0/0: process started
*Nov 1 13:59:23.855: CHAT0/0/0: Asserting DTR
*Nov 1 13:59:23.855: CHAT0/0/0: Chat script lte started
*Nov 1 13:59:23.855: CHAT0/0/0: Sending string: AT!CALL
*Nov 1 13:59:23.855: CHAT0/0/0: Expecting string: OK..
*Nov 1 13:59:26.575: new DSR value received, 1
*Nov 1 13:59:26.575: old value: handshakes->DSR= 1
*Nov 1 13:59:26.579: new DCD value received, 1
*Nov 1 13:59:26.579: old value: handshakes->DCD= 1
*Nov 1 13:59:26.639: new DSR value received, 1
*Nov 1 13:59:26.643: old value: handshakes->DSR= 1
*Nov 1 13:59:26.643: new DCD value received, 1
*Nov 1 13:59:26.643: old value: handshakes->DCD= 1
*Nov 1 13:59:26.675: Cellular0/0/0 DirectIP: Primary DNS address 88.82.13.12 added...
Router#sh cell 0/0/0 prof
Profile 1 = ACTIVE*
PDP Type = IPv4
PDP address = 10.121.253.230
Access Point Name (APN) = btmobile.bt.com
Username: bt
Password:
Primary DNS address = 88.82.13.12
Secondary DNS address = 88.82.13.12
* - Default profile
MTU 1500 bytes, BW 50000 Kbit/sec, DLY 100000 usec,
Last input 00:00:48, output never, output hang never
10 packets input, 280 bytes, 0 no buffer
DCD=up DSR=up DTR=up RTS=up CTS=up
Router#
*Nov 1 14:00:23.855: CHAT0/0/0: Timeout expecting: OK
*Nov 1 14:00:23.855: CHAT0/0/0: Chat script lte finished, status = Connection timed out; remote host not responding
*Nov 1 14:00:25.547: !!! CARDROP!!!!
*Nov 1 14:00:25.547: new DSR value received, 1
*Nov 1 14:00:25.547: old value: handshakes->DSR= 1
*Nov 1 14:00:25.547: new DCD value received, 0
*Nov 1 14:00:25.547: old value: handshakes->DCD= 0
*Nov 1 14:00:25.547: Cellular0/0/0 DirectIP: Remove negotiated IP interface address
*Nov 1 14:00:25.547: Cellular0/0/0 DirectIP: Primary DNS address 88.82.13.12 removed
Router#
So something is being triggered it is just the script does not get a response so the interface does not come out of spoofing.
Is teher any way to decode what the cellular debugs actually mean or how they should look?
11-01-2013 07:25 AM
Thanks for the additional information. If the source address of your ping will be 192.168.1.1 then I suggest that you modify your configuration of address translation and add a permit for 192.168.1.0. It has been my experience with 4G that providers reject traffic with that kind of source address and expect the source address to be in their address range.
Change your address translation, try the ping again, and let us know if the behavior changes.
Rick
11-05-2013 06:26 AM
I did try but it makes no difference. The Cellular interface does not, at this point, have an IP address so NAT is not performed (there is no IP to NAT to).
The failure is at Layer 2 in that the modem command does not get a response to activate the interface even though the profile is active (hence layer 1 is complete). The Provider never sees the IP packet as it is never sent.
This maybe one for TAC.
Chris Davis
11-07-2013 06:23 AM
It's a bug
so I entered
11-07-2013 06:44 AM
Thank you for the update and the explanation of the problem. That is very helpful information. Perhaps at this point you might mark the question as answered so that other readers would know that a solution has been found?
Rick
11-08-2013 07:34 AM
You can't mark your own replies as answers I'm afraid.
11-08-2013 08:09 AM
I guess that is right. In that case I will Endorse your response and it will be flagged in a somewhat similar way (not quite the same impact as you saying it is solved but at least it may get it a bit more attention as people read the forum).
Rick
