2 adsl dialers on the same router
hey,
i have 2 adsl lines i need to connect to 1 router. i can't change the pvc number or take 1 big line. i also need to have load sharing between the lines.
so far i did so by 2 vrfs - only way the lines work together, because of the same pvc as far as i know. i ran bgp and then i could route between the vrfs, but i can't ping to the dialer if it's in different vrf.
can someone help? thanks.
Silver
Re: 2 adsl dialers on the same router
Can you give me some configuration and digram what you have did??
Dharmesh Purohit
the configuration is followed, the diagram is attached.
the weird thing is i can route between different vrfs except for the dialer, which can be reached only from the same vrf.
configuration:
no ip domain lookup
ip domain name *****
ip name-server ***.***.***.***
ip dhcp pool 1
ip vrf LAN
rd 300:1
route-target export 300:1
route-target import 300:1
route-target import 100:1
route-target import 200:1
ip vrf vrf1
rd 100:1
route-target export 100:1
ip vrf vrf2
rd 200:1
route-target export 200:1
ip audit po max-events 100
interface Loopback0
ip vrf forwarding vrf1
ip address *****
interface Loopback1
ip vrf forwarding vrf2
ip address *****
interface Loopback2
ip vrf forwarding LAN
ip address *****
interface ATM0/0
ip address ******
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/48
pppoe-client dial-pool-number 1
interface FastEthernet0/0
** TO LAN ***
ip address *****
ip nat inside
speed 100
full-duplex
interface ATM0/1
ip address ****
pvc 8/48
pppoe-client dial-pool-number 2
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
ip cef accounting non-recursive external
ip nbar protocol-discovery
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username *******************
interface Dialer2
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
no cdp enable
router bgp 1
no synchronization
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf vrf2
redistribute connected
no auto-summary
no synchronization
exit-address-family
address-family ipv4 vrf vrf1
no auto-summary
no synchronization
exit-address-family
address-family ipv4 vrf LAN
no auto-summary
no synchronization
exit-address-family
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source list 2 interface Dialer2 overload
ip nat inside source route-map adsl1 interface Dialer1 vrf vrf1 overload
ip http server
no ip http secure-server
ip classless
ip route vrf LAN 0.0.0.0 0.0.0.0 Dialer1
ip route vrf vrf1 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit any
access-list 2 permit any
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
route-map adsl2 permit 10
match interface Dialer2
route-map adsl1 permit 10
match interface Dialer1
end
196
