12-23-2005 08:17 PM - edited 03-03-2019 11:18 AM
I am using a Cisco 2800 with 2 ADSL lines to the same ISP. Configuration is PPPoATM using Dialer interfaces. Have two static IP addresses from ISP. CEF is enabled on my router.
Can I utilise both the DSL lines for outgoing internet traffic? How can I be sure that both my links are being used effectively?
Should I go for Multilink PPP with virtual-template configuration to achieve this?
Vasanth
12-24-2005 10:35 AM
An update after I posted my questions:
Enabled CEF
Added two static routes
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2
Both ADSL connections are 512Kbps
I am facing a strange situation..Access to the Internet is slow now when compared to having just one line.
Any help/thoughts?
Thanks.
12-26-2005 04:09 AM
Make sure, that your ISP has the route towards your router links for the incoming traffic.
In this set up I would suggest to use MLPPP to achieve the best throughput. In case if that's not possible use " Radware linkproof" to achieve this. just installed it at one of my customer premises and got the fine results.
HTH,
-amit singh
12-26-2005 12:19 PM
The static IP addresses that I got from the ISP are reachable over the Internet. So, there is a route.
Thanks about that Radware linkproof box. I will investigate this option.
Meanwhile, can you tell me if it is OK to use just one address of the two addresses I got from the ISP for the virtual-template interface when I use MLPPP?
Vasanth
12-27-2005 12:40 AM
If you are getting single valide ip from ur SPyou can logically bundle 2 different channels and make use of the resultant B/W available in each induvidual channels.
But here since u will be assiged 2 different ips for the respective channels i would suggest to check out for policy based routing based on either ur destination or based on ur source.
Match the particular destination networks or applications and route it via one link and the remaining applications/networks via other link.
By doing this u can have see some balance on both the links instead of choking a particular link..
Also do u have any framed ips configured for ur uid or for ur public ip which u may be using in ur internal network or for mapping ur internal servers to the outside world...
regds
12-28-2005 11:09 AM
Hi Prem,
Thanks for the reply.
I did not get much about your question on framed ips..Are you talking about NAT?
I have NAT configured on my internet router and the internal address (which is coming from ISA Server) is mapped to both public addresses. I am not sure if there are any issues with NAT and CEF.
Coming to your point on load sharing based on source or destination IP...To the internet router, it only appears as if the traffic is coming from only one source which is the External NIC of the ISA Server.
90% of the traffic is HTTP and this is what I want to load balance. So, there is no point sending email traffic on one link and http on the other as I would be effectively using only one link and choking it.
Load balancing on destination traffic..well, it is all going to the Internet..no specific address I can type in on the router and do policy based routing..
I am thinking if I should ask my ISP to give me "one username, password and static IP address" for both links so that I can implement MLPPP.
What is the general practice from SP when you have multiple ADSL lines? Do they give you two different addresses?
Any other thoughts?
Vasanth
12-29-2005 02:12 AM
Hi Vasanth
I was mentioning Framed ip as the ip assignment in static fashion whenever ur login with the uid u will get the same ip.
Again u will have the rules set to activate a static route for the local lan network if any towards the particular uid/ip so that the local lan reachability can be made thru..
AFAIK its 2 diff ips which will be provided to the customer if they are taking 2 diff connections..
regds
12-29-2005 03:02 AM
In addition to ip cef try configuring ip load sharing per destination.
12-29-2005 05:14 AM
Hi Prem,
I am not negotiating any addresses from the ISP. ISP gave me two public addresses which I have configured on my dialer interfaces.
So, how is it that Multilink PPP possible if every ISP gives out one public address for each ADSL connection that you take?
regards,
Vasanth
12-29-2005 10:14 AM
Since you're using ADSL (note the "A), you will most definitely be "pulling" data from Internet rather then sending and this is due to an asymetric nature of ADSL. For the reason activating CEF and stuff, will not really help you much, because it's intended for outbound traffic, which should be rather small.
MLP is not an option in this case. As a side note, MLP operates on the LCP level, which comes before you get an IP address (NCP), meaning that you're aggregating the channels before any IP is assigned. Since these are separate ISPs which have their own LCP/NCP sessions, you would need like another hierarchy of LCP/NCP over existing LCP/NCP to do MLP here and this is not supported on Cisco routers.
To cut it short, you mentioned that you're also doing NAT on those internet routers. In my opinion your only options are to configure Multi-group HSRP or GLBP on the LAN side and load-balance traffic as it exits your LAN. Returning traffic (the important one) will hit the router which performed NAT becuase it will have its public IP as an overload.
So in essence, balance on the exit from LAN to balance the returning traffic.
Hope that helped.
David
12-29-2005 11:54 AM
Hi David,
That was a pretty convincing explanation. Thanks.
-- Vasanth
01-01-2006 11:55 AM
Hi David,
I just happen to read your reply again..Got a few questions.
You are talking about HSRP..I just have one router here with two ADSL cards in it and both connecting to the same ISP. Is not HSRP for two or more routers?
Let me restate again..To my internet border router, it only appears that the traffic is coming in only from one LAN address..So, load balancing by source address is not possible until I change a few things.
I have nat configured so that I translate this address to two public addresses I got from the ISP, one each for the Dialer interfaces and I have two static default routes.
The issue I have right now:
When both ADSL lines are connected, up and running, the second line is never used. But, it works independently when the first ADSL line is removed. So, no issues with the line as such.
Any help?
Vasanth
01-01-2006 12:22 PM
as you are connecting one internet router to the same ISP over two ADSL lines you could ask for MLPPP which would be the easiest solution for you. All you risk is getting a "No!" from your ISP.
In case of "No!": I think NAT could be the problem.
How do you configure this? Basically you configure NAT overload to the Dialer IP or interface. The NAT translation then determines the path out to the internet. And I believe you always take Dialer1 and never Dialer2, so only one line used. Can you verify this please with "show ip nat translation"? Could you post your NAT config?
On the other hand NAT order of operation inside to outside is first routing and then NAT.
So the suggestion for now is:
ip nat inside source interface Dialer1 overload
ip nat inside source interface Dialer2 overload
And you HAVE to make sure per destination load sharing is activated with CEF (actually the default). Otherwise the packets to an internet host might arrive with different source addresses and will be dropped, which slows internet down.
Check with show IP cef interface
Hope this helps
Martin
01-01-2006 08:46 PM
What you say is correct. Only Dialer 1 is used and I found that using "sh ip nat trans".
But, I do not see any problem with my config - IOS 12.3(14)T5.
Here is the config snippet:
interface Dialer1
ip address XX.XX.XX.XX/24
ip nat outside
encapsulation ppp
dialer pool 1
interface Dialer2
ip address YY.YY.YY.YY/24
ip nat outside
encapsulation ppp
dialer pool 2
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source list 2 interface Dialer2 overload
access-list 1 permit 10.1.0.0 0.0.255.255
access-list 2 permit 10.1.0.0 0.0.255.255
ip cef is enabled and the default is per-destination load sharing. So, I have not changed that.
ROUTER#sh cef interface dialer 2
Dialer2 is up (if_number 18)
Corresponding hwidb fast_if_number 18
Corresponding hwidb firstsw->if_number 18
Internet address is YY.YY.YY.YY/24
ICMP redirects are always sent
Per packet load-sharing is disabled
IP unicast RPF check is disabled
Inbound access list is allowin-dialer2
Outbound access list is not set
Interface is marked as point to point interface
Packets switched to this interface are dropped to the next slow path: Dialer
Hardware idb is Dialer2
Fast switching type 15, interface type 87
IP CEF switching enabled
IP CEF Feature Fast switching turbo vector
Input fast flags 0x400061, Input fast flags2 0x0, Output fast flags 0x10100, O
utput fast flags2 0x0
ifindex 13(13)
Slot -1 Slot unit -1 Unit 2 VC -1
Transmit limit accumulator 0x0 (0x0)
IP MTU 1500
01-03-2006 08:51 PM
Hi Martin,
When I used access-list with NAT as below, only dialer 1 was used and NAT translations did not show dialer 2 interface..
But, when I used route-map with NAT, translations for both are shown. "sh ip nat trans" shows both dialer interfaces with translations and both ADSL lines are being used now
ip nat inside source route-map adsl1 interface Dialer1 overload
ip nat inside source route-map adsl2 interface Dialer2 overload
route-map adsl2 permit 10
match interface Dialer2
route-map adsl1 permit 10
match interface Dialer1
Though my problem is solved, I am really stumped by this behaviour.
Any thoughts?
-- Vasanth
