2 Ethernet Interfaces and 2 PVC's on an 1841
What is the proper routing configuration when you have a router with two FastEthernet interfaces connected to two different networks and you want to route them out of two different PVC's? We are currently using static routing and only have one default route configured.
I would think all traffic is being routed over one PVC.
example:
interface Serial0/0/0.1 point-to-point
description *** Frame Relay PVC 1 ***
ip address 10.200.250.98 255.255.255.252
frame-relay interface-dlci 524 IETF
interface Serial0/0/0.2 point-to-point
description *** Frame Relay PVC 2 ***
ip address 10.200.254.58 255.255.255.252
frame-relay interface-dlci 500 IETF
ip route 0.0.0.0 0.0.0.0 10.200.254.57
Would you use PBR to define which sub-interface to route out or is there another way?
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
Re: 2 Ethernet Interfaces and 2 PVC's on an 1841
Ryan
Based on what you have shown us so far and what you have described, I would say that yes PBR is the solution to have traffic from one FastEthernet go out 1 frame relay subinterface and traffic from the other FastEthernet go out the other frame relay subinterface.
And yes what you have posted would result in all traffic being routed out a single subinterface.
Rick
You'll have to create a route-map permiting the networks you want for each interface. So basically a permit / deny and then set your next hop gateway.
Ryan
Rick
Thanks. I just wanted to make sure I was headed down the correct path.
Ryan
I am glad that my response was helpful in resolving your question. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that there were responses which were successful in helping to resolve the question.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
255
