Community Member
(2) IP ranges over Multilink Frame Relay via 3xT1
I have (2) external IP ranges I'd like to assign to a multilink frame relay interface, both of which are controlled by the same ISP. The frame relay is bundling (3) T1s into a 3xT1 running on a Cisco 2821 with IOS Version 12.4(25).
I successfully have the following config running, except for sub-int .501 which I will be adding once the routing is changed with the ISP for the additional range.
Two questions:
1. Will the below config function correctly since the DLCI is being duplicated on the subinterfaces?
2. Will I need an additional DLCI even though it's probably connecting to the same DCE frame-relay switch?
Let me know if there is a better configuration for this setup.
controller T1 0/0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 0/0/1
framing esf
linecode b8zs
controller T1 0/1/0
framing esf
linecode b8zs
controller T1 0/1/1
framing esf
linecode b8zs
interface MFR0
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type ansi
interface MFR0.500 point-to-point
ip unnumbered GigabitEthernet0/0
no cdp enable
frame-relay interface-dlci 500
interface MFR0.501 point-to-point
ip unnumbered GigabitEthernet0/1
no cdp enable
interface GigabitEthernet0/0
ip address xx.xx.xx.xx 255.255.255.128
duplex auto
speed auto
interface GigabitEthernet0/1
ip address yy.yy.yy.yy 255.255.255.128
duplex auto
speed auto
interface Serial0/0/0:0
no ip address
encapsulation frame-relay MFR0
no arp frame-relay
frame-relay multilink lid link3
interface Serial0/0/1:0
no ip address
no arp frame-relay
frame-relay multilink lid link1
interface Serial0/1/0:0
no ip address
no arp frame-relay
frame-relay multilink lid link2
interface Serial0/1/1:0
no ip address
ip route 0.0.0.0 0.0.0.0 MFR0.501
Hall of Fame Super Silver
Re: (2) IP ranges over Multilink Frame Relay via 3xT1
Hello Adam,
this config is not correct the same DLCI cannot be associated to two different subinterfaces.
You need to negotiate with ISP a second DLCI to be used on the second subif.
Then each subif can accomodate a different ip subnet, for example in the way you have done with ip unnumbered.
Look at the MFR interface as a normal serial interface with FR encapsulation the same rules apply here.
Edit:
for outbound load balancing you will need a second default static route using the other subif as exit point.
Hope to help
Giuseppe
Community Member
Does outbound load balancing really matter since regardless of outgoing sub-interface, all traffic is being bundled over MFR0 via the 3xT1?
Thank you for your help.
-Adam
Hello Adam,
that's right but symmetric solutions are better unless NAT is involved.
In case one DLCI is deleted on FR switch the other one still allows you to go out.
If you use NAT it is probably better to have a second floating static route to avoid to mix up with translations
Hope to help
Giuseppe
169
