2 LAN's on a Cisco 877 possible
Hi, I'm not sure if this is possible, but I have a Cisco 877 in a remote office that is setup as a VPN our head office. At the remote site where the 887 is there is a another LAN that we want the remote office to use, but this remote office's 2nd LAN can't connect to the VPN, possible? There are 3 spare FE ports on the back can the other LAN plug into that somehow and be segmented to only use that local LAN?
Hall of Fame Super Gold
Re: 2 LAN's on a Cisco 877 possible
If you have an "advaced ip service" image you can configure vlans and assign an own port for that.
Else you can only configure the additional sybnest as "secondary" under VLAN 1 and connect to any port you want.
Thanks, how would I configure the sybnest as secondary?
I suppose routing would stop the traffic going over the VPN as this other LAN cannot have access.
interface XXX
ip address
secondary.
If the crypto map is configured to build a security association for that network too, it will be sent over VPN. Routing doesn't have a direct role in that.
121
