2 T1's load balancing connecting point to point
D0nprintup_2
I have two locations.
Location 1:
interface Serial0/0
description ID XXX
bandwidth 1544
ip address 192.168.252.1 255.255.255.252
no ip directed-broadcast
ip load-sharing per-packet
no ip mroute-cache
no cdp enable
description YYY
ip address 192.168.250.1 255.255.255.252
priority-group 1
no cdp enable
bridge-group 1
Location 2:
interface Serial0/0/0
description XXXX
ip address 192.168.250.2 255.255.255.252
service-module t1 remote-alarm-enable
no cdp enable
interface Serial0/3/0
description YYYY
ip address 192.168.252.2 255.255.255.252
no cdp enable
ok
on site two they have dsu/csu built into the wic. There is a RJ45 conencting to the smart jacks for both ciruits. On site 1 there is a CSU/DSU.
Over the last week Site two serial0/3/0 has been going down/down. Site 1 shows up/down. (BEcause it see's the line to the CSU/DSU im taking it).
I called the carrier and they are able to connect and loop to site 1. They can connect and see site two's smart jack. Unable to loop but there is no separate CSU/DSU.
I understand this may be a physical problem. cabling or internal card. I am in the process of making a loopback cable and replacing the current cable.
My question is, because this is a point to point connectin. Shouldnt there be a clock rate command on one side of this connection?
thanks
Richard Burts
Donald
I am not sure why you would think there should be a clock rate command just because it is point to point. With CSU/DSU and connection to the provider network, it is likely that they are providing clock for the circuit - and in that case you do not need (and do not want) clock rate in your config.
Rick
Rick
Collin Clark
Check the speed of your channels. It will not show up in your config. Most in US should be set to 64Kb/s.
RTR1(config-controller)#channel-group 0 timeslots 24 speed ?
48 48 Kb/s
56 56 Kb/s
64 64 Kb/s
