2509 routing issue
hi,
i have cisco 2509 router with 10.2 ver IOS. I am able to ping to my ISP DNS as well as extended ping from the router, but am not able to do it from my laptop(public Ip configured)directly connected to the routr . My default gateway and dns is configured correctly and am able to ping the router from my laptop ,but not dns of ISP and am not able to browse.Instead of deafault route ,defualt gateway command is used in the router. here is the config.
version 10.2
no service tcp-small-servers
hostname xxxxx
enable secret 5 $1$CBzO$PT.acGFG02PweeEKLReiZ.
username medrc password 7 11041C010511
ip subnet-zero
interface Ethernet0
ip address xxxxxxxxxx xxxxxxxxxxxxxxxxxxxxx
no ip route-cache
interface Serial0
no ip route-cache
interface Serial1
no ip address
no ip route-cache
shutdown
ip default-gateway xxxxxxxxxxxxxx
ip domain-name xxxxx.om
ip name-server xxxxxxxxxxx
ip name-server xxxxxxxxxxxxx
line con 0
exec-timeout 0 0
password xxxxxx
line 1 8
transport input all
line aux 0
transport input all
line vty 0 4
password xxxxxxxx
login
end
Please help
1 ACCEPTED SOLUTION
Re: 2509 routing issue
just put the static route in your router.....plus can u ping your pc and your pc can ping your serial interface.......
ip route 0.0.0.0 255.255.255.255 serial 1
Please trace your DNS from LAPTOP & check the HOPS....
Akhtar
hi,
i tried the trace ,but its nt going..But i am able to ping the serial interface from laptop.i am not able to add route command. intead it has Ip default-gateway command.
hi,
my problem got solved. the issue was router was in miniIOS mode. reimaged the router and now its working fine and am able to add route.
Savad
142
