Webcast-Catalyst9k
2600 ASYNC Issue
Hi Gang,
We have about 900 2600 Cisco Routers which we use for Out-Of-Band Management Access to numerous Devices all across the states.
Recently one of our vendor warranties has reached the end of contract and with all the Remote Testing Units on Site we have come across a slight issue which i need a little 101 refresher course on.
router# > sho line 36
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns
36 TTY 9600/9600 - - - - - 32 0 0/0
Line 36, Location: "", Type: ""
Length: 24 lines, Width: 80 columns
Baud rate (TX/RX) is 9600/9600, no parity, 2 stopbits, 8 databits
Status: Ready
Capabilities: EXEC Suppressed
Modem state: Ready
Modem hardware state: noCTS* DSR DTR RTS
Special Chars: Escape Hold Stop Start Disconnect Activation
^^x none - - none
Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch
00:10:00 00:02:00 none not set
Idle Session Disconnect Warning
never
Login-sequence User Response
00:00:30
Autoselect Initial Wait
not set
Modem type is unknown.
Session limit is not set.
Time since activation: never
Editing is enabled.
History is enabled, history size is 10.
DNS resolution in show commands is enabled
Full user help is disabled
Allowed transports are pad v120 telnet rlogin. Preferred is telnet.
No output characters are padded
No special data dispatching characters
My question is, I used to be able to determine whether the Hardware MODEM State (ex: noCTS* DSR DTR RTS) was physical or logical config issue. This was a LONG time ago. My memory escapes me now, but can anyone break it down as per how to differentiate noCTR, CTR* CTR and etc...
Thank you kindly,
UpArrow
Quote
"...a telecommunications company yet you lack communication..."
420
