06-27-2012 06:52 AM - edited 03-04-2019 04:48 PM
Greetings!
I am still getting my brain around all of a nuances of my routers.
We are upgrading our incoming Internet service from 30 Mb 10/100 to 100Mb 10/1,000.
Will my 2600 series router support the 10Mb 10/1,000 traffic from my new modem?
Do I need to change my interface speed from 100 to 1,000?
I to be sure my router will support the upgrade. Thank you in advance.
Nancy
ROUTER01#show int
FastEthernet0/0 is up, line protocol is up
Hardware is AmdFE, address is 0009.e811.cf20 (bia 0009.e811.cf20)
Internet address is 10.10.20.xxx/xx
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 3/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 3w3d
Input queue: 0/75/13/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1202000 bits/sec, 111 packets/sec
5 minute output rate 88000 bits/sec, 64 packets/sec
133785526 packets input, 2418050500 bytes
Received 148666 broadcasts, 0 runts, 0 giants, 0 throttles
333708 input errors, 333708 CRC, 826 frame, 0 overrun, 0 ignored
0 watchdog
interface FastEthernet0/0
ip address 10.10.xxx.xxx 255.255.255.0
ip nat outside
speed 100
full-duplex
no cdp enable
111265933 packets output, 333217074 bytes, 0 underruns
0 lost carrier, 0 no carrier
Solved! Go to Solution.
06-28-2012 12:46 AM
I believe your current speed for that interface is 100mbps, so you dont need to change the speed.
06-28-2012 11:52 AM
You cannot use an old 2600 router for high speed internet access, because it doesn't have enough performances. See attachment.
06-27-2012 09:24 AM
Hi nancy,
As per my understanding, you want to upgrade your isp bandwidth to 100mbps with 10/1000 ratio, can you confirm this?
If yes then i think you can use the current interface (your fastethernet interface). But im suggesting you to monitor that interface, if you find the interface load is full, or you find some error on the show interface command, then i think you may proceed with the interface upgrade.
06-27-2012 04:15 PM
Handoko,
Yes we are upgrade t 100mbps with 10/1000.
Do I need to change the speed on the interface?
Thank you,
Nancy
06-28-2012 12:46 AM
06-28-2012 09:28 AM
Thank you Handoko! I will watch for network congestion.
06-28-2012 11:52 AM
06-28-2012 03:45 PM
I agree with Paolo's post. You don't need a new modem. You need a new ROUTER that can push 10 Mbps of traffic, full duplex.
06-29-2012 02:36 AM
hi paolo & leo, thanks for joining us here.
as im aware of 2600 is quite old router, but the internet traffic is using 1/100 ratio based. as per my understanding if we subscribe for 10mbps link, at the ISP side its actually 10mbps use by 100 subscriber, means if the other 99 subscriber are off, then we can get the actual 10 mbps link.
based on this understanding, im suggesting that nancy can go ahead with the upgrade, but with monitoring the interface load & the router performance.
but, if my ratio based internet traffic understanding was false, means nancy will use full 100mbps internet link 1/1 ratio based, im totally agree with both of you.
regards,
ps: nice docs you have there paolo.
06-30-2012 07:58 AM
New router is on order. Thank you for your help everyone.
