Community Member
2610 WIC 1 ADSLinstallation problem
I have recently installed a WIC1 ADSL into my cisco 2610 Router. After inserting the module into the router it is shown as unrecognised when the interfaces come on-line at boot.
As shown here;
Press RETURN to get started!
Unknown WIC in slot(0/0), wic card has an unknown id of 0x2E
I am have googled for an hour anow and had no luck, though i have seen this problem with other types of WICs from my results, none with a solution posted.
Useful information;
show diag..
Router#show diag
Slot 0:
C2610 1E Mainboard Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 2.3
PCB Serial Number : JAD054005SQ (264376625)
Part Number : 73-2839-13
RMA History : 00
RMA Number : 0-0-0-0
Board Revision : C0
Deviation Number : 0-26213
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 91 41 02 03 C1 17 4A 41 44 30 35 34
0x10: 30 30 35 53 51 20 28 32 36 34 33 37 36 36 32 35
0x20: 29 82 49 0B 17 0D 04 00 81 00 00 00 00 42 43 30
0x30: 80 00 00 66 65 FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
DSL SAR (ADSL)
Part Number : 73-4771-08
Board Revision : A0
Deviation Number : 0-0
Fab Version : 05
PCB Serial Number : VMS06330RWB
RMA Test History : 00
RMA History : 00
0x00: 04 FF 40 00 2E 41 02 03 82 49 12 A3 08 42 41 30
0x10: 80 00 00 00 00 02 05 C1 8B 56 4D 53 30 36 33 33
0x20: 30 52 57 42 03 00 81 00 00 00 00 04 00 FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 1:
Serial 1T WAN daughter card
Hardware revision 1.0 Board revision J0
Serial number 34070431 Part number 800-46570-01
Test history 0x0 RMA number 00-00-00
Connector type Wan Module
EEPROM format version 1
0x20: 01 02 01 00 02 07 DF 9F 50 B5 EA 01 00 00 00 00
0x30: 98 00 00 00 11 11 26 01 FF FF FF FF FF FF FF FF
Show version...
Router# sho ver
IOS (tm) C2600 Software (C2600-IO3-M), Version 12.3(3), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 19-Aug-03 16:32 by dchih
Image text-base: 0x80008098, data-base: 0x80D11A24
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Router uptime is 1 hour, 45 minutes
System image file is "flash:c2600-io3-mz.123-3.bin"
cisco 2610 (MPC860) processor (revision 0x203) with 28672K/4096K bytes of memory
Processor board ID JAD054005SQ (264376625)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
1 REPLY
Re: 2610 WIC 1 ADSLinstallation problem
It depends on the exact type of DSL module that you have. Please check the text below that was copied from the following Q&A page:
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_q_and_a_item09186a0080093bff.shtml#a
The ADSL feature is supported in the IP/ADSL Image ("y7" image) for the Cisco 1700 Series. The Cisco 2600/3600/3700 series routers require a PLUS Cisco IOS Software image for ADSL if version 12.2T is in use. From Cisco IOS Software Release12.3 mainline and later, ADSL WIC support is available in the "IP Base" feature set. Some Quality of Service (QoS) features require an advanced image (IP PLUS, IP VOICE, or later) for Cisco 1700/2600/3600/3700 series router support.
The ADSL over POTS WIC (WIC-1ADSL), is available on the Cisco IOS 12.2(13)T Release for the Cisco 1700/2600/ 3600/3700 series routers.
The ADSL over POTS WIC with Dying Gasp Support (WIC-1ADSL-DG) is available on Cisco IOS Software Release 12.2(15)ZL for the 1700 Series. This release merges into the third release of the Cisco IOS Software12.3T train in the first calendar quarter of 2004. The WIC-1ADSL-DG is first available on the Cisco IOS Release 12.3(4)XD for the Cisco 2600XM, 2691, and 3700 Series and is supported in the third release of the 12.3T software train as of 2004.
The ADSL over ISDN WIC (WIC-1ADSL-I-DG) is available on the Cisco IOS Software version 12.2(13)ZH for the Cisco 1700 series and will be available on Cisco IOS Software version 12.2(15)ZJ for the Cisco 2600XM, 2691, and 3700 series routers. All WIC-1ADSL-I-DG features in 12.2(13)ZH and 12.2(15)ZJ is supported in the second release of the Cisco IOS Software 12.3T train (available in the fourth quarter of calendar year 2003). This date is subject to change. For a comprehensive list of images that support the ADSL over ISDN WIC on the Cisco 1700 Series, refer to the Cisco IOS Release 12.2(13)ZH product bulletin number 2135 and future releases on Cisco.com.
Leo
251
