2611 got so many packet error, crc and collision
1guanaswitch
Dear All,
I implemented rate-limit using 2611, but when i see the interface statistic i saw so many packet error, CRC, and Collision. Which cause the network become unstable and so slow, i have to clear ip nat translation, logging, and dhcp binding and even to reload the router first to make it works normal again. But after a while it happened again. All my switches using catalyst 2924. If i use 2611 just for simple routing without rate-limit, no packet error, crc, or collision.
Any idea what was wrong with the router? I used IOS 12.3(5a). Thanks before.
smalkeric
Level 6
Level 6
To limit the rate of messages logged per second, you can use the logging rate-limit command in global configuration mode
The following URL may help you:
http://www.cisco.com/en/US/docs/ios/12_2/configfun/command/reference/frf013.html#wp1170448
thanks for replying...
i've set the logging rate-limit... but how do i know what causing the interface have packet error, crc and collision??
is it because the interface on 2611 only 10mbps (ethernet) while the catalyst using 100mbps (fast ethernet) which become bottle neck??
It most likely would be a duplex mismatch (one side running half duplex, the other is running full duplex.
Try manually setting both sides.
Good Luck
Scott
