Webcast-Catalyst9k
2620 and Cisco SDM
We are currently running c2600-is-mz.120-7.T2.bin on a 2620. We would like to use Cisco SDM to monitor the router.
We only have the following memory :-
libabb#sh vers
IOS (tm) C2600 Software (C2600-IS-M), Version 12.0(7)T2, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sun 10-Feb-02 00:28 by ccai
Image text-base: 0x80008088, data-base: 0x80C52A94
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
libabb uptime is 21 weeks, 5 days, 9 hours, 53 minutes
System image file is "flash:c2600-is-mz.120-7.T2.bin"
cisco 2620 (MPC860) processor (revision 0x600) with 26624K/6144K bytes of memory
Processor board ID JAD05500NBS (231475022)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
libabb#dir
Directory of flash:/
1 -rw- 7331652 <no date> c2600-is-mz.120-7.T2.bin
8388608 bytes total (1056892 bytes free)
Can you please advise on a IOS version we should use, and if we need to upgrade the flash/ DRAM etc to run Cisco SDM.
Cheers
1 REPLY
Hall of Fame Super Bronze
Re: 2620 and Cisco SDM
SDM version 2.1 and later can be installed on a PC, no need to worry about the router's flash space.
However, SDM does not support non-XM 2600 routers - which is the model you are currently running.
Please check out its readme at:
http://ftp-sj.cisco.com/pub/web/sdm/SDMv2.4.1-Readme.html
834
