Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
2620xm
HI
IOS 12.4 Advanced Enterprise Services willWorking on the 2620xm;if so how much the flash & Dram should be?
regards
ali
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: 2620xm
ali
The size of the image is the same no matter whether it is in a lab or in production so the requirements for flash should be the same.
You probably do not need quite as much memory to run in a lab as to run in production. But I do not think that it changes the requirement for memory very much.
If your router has less flash or less memory than the requirements stated you could always try to load the image and see what happens. But if it were me I would be reluctant to try to load and run an image on a router that had less than the required resources.
Rick
Re: 2620xm
ali
According to the Software Advisor on CCO 12.4 Advanced Enterprise Services should have 128 of memory and 32 of flash.
Rick
Re: 2620xm
HI RICK!
We need this routers/ios 12.4 for lab not for production;now waht is ur opinion rick
10xs
Re: 2620xm
ali
Rick
Re: 2620xm
Hi Rick!
Thanks a lot for ur valuable info
10xs
142
