2800/3800 ISR :New Satellite WAN module
Hi : Has anyone tested this NM.Cisco IP VSAT satellite WAN network module (NM-1VSAT-GILAT).
I am looking for specs on this NM, also, if it support encryption (AES) and IP routing, any limitations?
thank you
Silver
Re: 2800/3800 ISR :New Satellite WAN module
Cisco VSAT module is a 2-way
Satellite WAN interface card that provides broadband connectivity over
Satellite. It works with Gilat Skyedge Hub and requires a Ku-band ODU
(outdoor unit consisting of an antenna and transmitter/receiver
Thank you .
Does it support two way encryption ?
also, does it support running IP routing protocols across the air ?
thank you
93
