Community Member
2800 and modules.
Hi all,
pls.could someone recommend me
how could I populate for instance C2821
with additional FastEthernet or Gig port? Is over there some module with only one mentioned type of port?
I know that 2821 has on board 2x Ge.
BR
jl
Re: 2800 and modules.
For a min. you will get a hwic with 4 switch ports on it and then configure vlans on those ports to get layer 3 functionality. Remember some features are not supported on the hwics. or else you can use a NM which will give you 16 ports for a min.
Community Member
Hi Sankar Nair,
first thanks for help :)
Second ,which NM can I use for additional eth/fast
conn.?
When I use HWIC with 4 ports can I connect one of
those ports to router on opposite peer.
I need to have L3 interface.
If it is not possible, why I cannot do this on 2800
and on 2600 I can, with NM-1E...?
Thanks a lot for advice.
BR
jl
hi
I feel the support for the standalone Ethernet ports arent there in the new ISR series boxes instead you got to have the support for ESW(Ethernet Switching Network Modules).I would suggest you to check the link to find out the relevant modules which are supported in 2800 ISR series..
http://cisco.com/en/US/products/ps5854/products_relevant_interfaces_and_modules.html
regds
Community Member
Ok, fellows.
Thanks for advice...its helpful for me.
BR
jl
123
