2801 fastethernet down
Joli Martinez
I have a 2801 router.  The Fa0/0 int shows up/down.  I have plugged it into diffrent cisco and non cisco switches and even a cross over cable to my laptop.  I cant seem to get the protocol up.  I have changed the speed to 100 and duplex to full to try to get it up that way and nothing.  This is what I have:
interface FastEthernet0/0
ip address 10.105.1.253 255.255.255.0
duplex auto
speed auto
again as you can see nothing out of the ordinary. any ideas?
cadet alain
router to switch is straight through cable, are you sure you selected the correct cable?
How are the the link leds when connecting the 2 ?
Regards.
Alain
7 Replies 7
cadet alain
Regards.
Alain
yes,  2801 -> switch using straight through.  I have verified cable works.  and all light on both the router and the switch being plugged into are solid green.  Also verified the swith port works.
FYI.  I deleted all configs and all I have done so far is put an ip address on the FA0/0 int and did a no shut
when I do "ping 10.105.1.253 source fa0/0" from itself I get
Invalid source interface - IP not enabled or interface is down
and the 10 ip address is the one assigned to Fa0/0
same thing with loopback
r3#ping 127.0.0.1 source fastEthernet 0/0
% Invalid source interface - IP not enabled or interface is down
if the interface is down then the ping won't work and there is no loopback( 127.x.x.x/8) on a router, this is on hosts for testing their tcp/ip stack.
But you marked the thread as resolved and it is not, why did you do so?
What about connecting f0/1? is it still the same to what type of switch port are you connected?
Regards.
Alain
I am having the same issue with fa0/1.  Blank config and all I am doing is giving the int an ip address. I know that i can ping 10.105.1.254 because I have connected my PC to the same switch and it works.  I have tried both setting the mode to trunk and to access and neither of them work?
any ideas?
just to be sure:
sh ip int br on the router and sh int status on the switch
Regards.
Alain.
sh ip int brief on router shows up/down
sh ip int brief on switch shows up/up
sorry i found the problem.  After all this time.  The cable was bad.
lol
thx for the help.
