01-17-2007 09:13 PM - edited 03-03-2019 03:24 PM
Thought IOS would be easy but not to be on this one.
Issued the command copy tftp flash command from exec mode. It asked for tftp ip, source file and destination file. The copy went fine.
Then to check whether the ios has been copied to flash. I entered the command show flash, but the new image is not found there.
Then again I repeated the procedure, it then says file already exists with file name, do you want to overwrite. answered yes.
Is there something I am missing here??
01-17-2007 10:18 PM
Hi Saba
Can you post the output of the command show flash ?
regds
01-17-2007 10:33 PM
It seems you are missing out on the filename.
Check with the filename. As everything seems to be fine, you are coyping it properly and rest...
