2801 Router with 2 x ADSL Connections
I have a Cisco 2801 running advanced ip services tht already has a single DSL connection to the internet that is configured for VPN access. A DMZ has been configured to a single 2960 switch with a webmail serevr. All is working perfectly well .....
I now have a requirement to add another DSL connection that is to be kept seperate from the existing DSL connection and a ISA/Proxy server to be used with it to filter/monitor web traffic.
Can someone advise if this is possible on my single 2801 router and perhaps post a sample config ??
Stuart
Hall of Fame Super Gold
Re: 2801 Router with 2 x ADSL Connections
Yes is't possible, by use of route maps in nat statements. Basically you define which inside adressess do use which interface.
Thanks for the quick reply.
Do you have an example I can follow or perhaps a link to a white paper ?
Thanks again,
From the nat page:
http://cisco.com/en/US/tech/tk648/tk361/tech_configuration_examples_list.html
choose an example like dual interface router.
163
