2801 with 3 ADSL Lines
duncan-1gp
Is there any problem with using a 2801 router with 3 ADSL/POTS interface cards and three lines?
Yes. Just make sure that you have three default routes, static, or learned via DHCP. Then you will also have three NAT statements.
paolo bevilacqua
There should be no problem.
Cheers, and would it possible to load-balance against the three gateways?
Thanks!
