2801 with 3 ADSL Lines
Is there any problem with using a 2801 router with 3 ADSL/POTS interface cards and three lines?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: 2801 with 3 ADSL Lines
Yes. Just make sure that you have three default routes, static, or learned via DHCP. Then you will also have three NAT statements.
There should be no problem.
Cheers, and would it possible to load-balance against the three gateways?
Thanks!
125
