Webcast-Catalyst9k
2811 and FTP issues
Hi, anyone already experienced some problem with Plataform 2811 with IOS 12.3.T10 and T11, SP Services K9 regarding FTP?
I mean, something related to problems with download and upload in a Windows FTP plataform?
Note that command ip tcp path-mtu-discovery is configured and the problem persists. Do I need to try adjust the MSS size in Fast ethernet? Which size?
Any help is welcome.
Tks a lot.
VIP Purple
Re: 2811 and FTP issues
you could try:
ip tcp adjust-mss 1350
on the FastEthernet interface.
GP
I just met similar problem with 2811.
It seems there is a difference between pulling and pushing the IOS from/to the Flash.
While started FTP server on both routers and using copy flash: ftp: it works fine.
But copy ftp: flash: is much slower or fails.
There might also be some FW involved, I'll keep investigating.
Best regards,
Milan
261
