Community Member
2811 CCME + WLAN compatability
Not to sure where to stick this post, so i put it in here :)
I am proposing 2811-CCME-K9 bundles for a clients WAN and IP Telephony. I want to add thye WLAN net Mod controller but it is unavailable in the configurator ???
However if i build the box from scratch without using teh bundle i can include it ??
is there any reason for this and i am guessing there is not technical reason why the
NM-AIR-WLC6-K9 cant be added to the CISCO2811-CCME/K9
Super Bronze
Re: 2811 CCME + WLAN compatability
Basically the bundles you are using are just standard routers, with a better (SP Services) version of IOS, DSPs for voice, and the CME feature license.
There's no reason why you can't add anything to it, provided that the version of IOS you use and the feature set (SP Services) supports the bits you want to add.
Just check on the docs online on to ensure that the minimum IOS ver and feature set (if any) are met.
I'm assuming of course that you aren't using your network module for a Voicemail (Unity Express) NM? If you require Voicemail you can use the AIM version that fits internally....
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Community Member
HI Buddy
I have this code in my lab and support CME and Nm-air-WLC module
Download and check if it works
I am only using this code for my my wireless but later on i want to work on VO-wi solution ,but try it and let me know
if you cannot pull the code send  me a dropbox site, and i will upload it for you
