Webcast-Catalyst9k
2811 ds3 speeds
The 2811 says it supports partial t3 speeds, how partial are they? What is the maximum useable link speed it can support?
thanks
1 REPLY
VIP Purple
Re: 2811 ds3 speeds
Hello Ken,
I have searched for what exactly is meant by ´subrate´ T3/E3 support, and I think they mean that the supported rates are as following:
34010 kbps for E3 or PA-E3
44210 kbps for T3
44736 kbps for PA-T3
In the technical specifications of the NM-1T3/E3 they talk about the full and half duplex speeds supported, which match the values above...
Have a look at the document below, and scroll down to ´Hardware Specifications´:
Cisco T3/E3 Network Module
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a008010fba2.html
HTH,
GP
341
