2811 E1
I have cisco 2811 with VWIC-2T1/E1-RAN installed. I have IOS
(C2800NM-IPVOICE-M), Version 12.4(18)
But it is not recognizing the E1 card.even card router is not recognizing the card type command.
WIC Slot 0:
Unknown WAN daughter card
WIC module not supported/disabled in this slot
Hardware Revision : 3.0
Top Assy. Part Number : 800-25833-03
Board Revision : E0
Deviation Number : 0-0
Fab Version : 02
PCB Serial Number : FOC11302ZTB
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Version Identifier : V01
Product (FRU) Number : VWIC-2T1/E1-RAN
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 04 BF 41 03 00 C0 46 03 20 00 64 E9 03
Please tell me which IOS will support these commands.
  • WAN Routing and Switching
Hall of Fame Super Gold
Re: 2811 E1
That card is special made for telco and wireless operators, and is supported only in selected images. Please try an image from 12.4(11)SW3.
Re: 2811 E1
Thanks for the reply, I upgrade the IOs 12.4(11)SW3 and now i am able to get the E1 card.
Thanks for the help and support.
112
